Sponsored by: Auxito
NO Start issue.
Old Yesterday | 02:52 PM
DCrusher's Avatar
DCrusher
NO Start issue.
Well Mom called and said her truck will not start so went over there and took a reading on the battery it was 11.0VDC so tried jumpers and manage to get 13.5 on to it still no start so took jumpers off and checked battery again 12.0 so looked at battery it was 6 years old so that has to be it so went and bought another battery installed it nothing still. Crawled under it jumper from POS battery post to the solenoid and it engages the starter and turns over so some where in between the starter and the ignition switch I have lost my 12VCD telling the starter to engage. HELP I have worked on a new 2003 F-150 in ten years.
I meant to ask on the older truck they had a starter solenoid on the wall is the round thing next to the battery have anything to do with the starting it the original 2003 one and how do you check it??
Old Yesterday | 03:15 PM
Jon Freeman's Avatar
Jon Freeman
This may help
Old Yesterday | 05:25 PM
BareBonesXL's Avatar
BareBonesXL
The other thing the guy should have done though was to check for voltage on that small pressed-on wire to the right, with the key at Start. That's what powers the solenoid to cause those two big wires to be connected. Pop the wire off of the terminal, stick a meter lead or a test light in the plug and turn the key to Start. If the light doesn't light or there's no voltage shown there's a problem with the ignition switch or the wiring. Solenoid (starter relay) is highly likely though.
Good video though.
Old Today | 09:10 AM
DCrusher's Avatar
DCrusher
Good video though.
yap Have no power on the white/red wire to solenoid so it’s either ignition switch or neutral safety switch
TroyBlueFord
2015 - 2020 F150
Dec 12, 2025 07:24 AM
Tees77f150
15
Jun 27, 2022 04:53 PM
bigenough
17
Apr 25, 2021 07:13 AM
cnolin
Oct 2, 2003 05:49 PM
Woodster
1983 - 2012 Ranger & B-Series
Sep 16, 2003 11:44 PM
