02 7.3 that I've had for 21 years. Trying to figure out a starting issue. Starts fine plugged in down to about 0 F, when not plugged in, 50 degrees is about the cutoff. If it doesn't pop or chug in the first few seconds of cranking , I can crank it till the cows come home and its just a dead crank. It's only within the first couple seconds of cranking it decides to try to start or not. Problem started not too terribly long after I had engine out for oil pan. Did glow plugs valve cover harnesses at that time less than 3 years ago. Cranks good and fast, good batteries and starter. Any ideas? Didn't seem real similar to any other symptoms I've heard of other than maybe lpop? I have had it cut out while driving here and there but I was thinking that was the fuel pedal acting up since letting off and getting back on it will clear it up and keeps driving. Mileage is around 180k.
I switched to 5w40 full synthetic, that made a tremendous amount of difference.
Before, with 15w40, it performed exactly as you explained.
I also installed a high power geared starter that spins it at almost 200 RPM.
no block heater and it starts at 20* now easily, and idles smooth right off.
Oklahoma does not ever get below zero annually, we had our first deep freeze 2 years ago, at -25* for 10 days. I didn't even try to start it, we have several gasoline cars and trucks here, all of them start easily ... in cold Wx.
I keep Battery Tenders on everything when the temps drop below 30*
I have a couple of Magnetic oil pan heaters, get one or two of those and stick them on the bottom of the Oil Pan, that will keep things at 60* or more and solve your problem. won't need the block heater, but it will heat the coolant up some.
those oil pan heaters are left over from when I worked in NW Utah and we had a -59* deep freeze come thru, the Suburban's 454 starts easy when the oil temp is 100*
I have considered thinner oil but I think theres a deeper root cause as its always started much better even not plugged in down to about 10 degrees. It's just strange to me that its always in the 1st couple seconds of the key cycle that it'll pop off if its going to. It may be the 20th key cycle but only pops or starts in the first couple seconds. Ive just resorted to driving my suburban in colder weather instead, which does keep more salt off the old girl so there is one benefit but here in MN thats about half the year!
Have you checked the glow plug relay to make sure it’s energizing the system? Cheap and easier than a LPOP. When you first turn the key on the second big post should have battery voltage on it or if you have a way to monitor voltage in the cab there should be a substantial voltage drop from the glow plugs turning on.
What is cranking speed? less than 200 isnt good
Are you waiting for the Glowplugs to warm up first? if no then you are cranking before its ready
Are your glowplugs all working? if not it can be tough to start under 50
Do you have a scanner? if not we can guess at a lot pf parts that will drain your wallet
Test 1: Check for glow plug relay activation. It's the relay further back and is usually shorter. Touch the relay case and have a helper turn the ignition the the ON position. You should hear and feel the relay activate.
Test 2: If test 1 passes, connect voltmeter leads to the 2 large terminals of the relay. You should read battery voltage there. Have a helper turn the ignition to the ON position. The reading should drop close to 0 volts. If the reading doesn't change, replace the relay.
Thsnks for the replies, I won't be around my truck for a few weeks or more to try any diagnostics yet but trying to get some ideas for now. The glow plugs were motorcraft , can't seem to find where I purchased, I tested the GPR a few months ago with just a test light and seemed to be operating correctly. I let the glow plugs cycle initially for up to a few minutes turning the key back off /on 2-3 times and doesnt seem to make a difference. Then after a few long glow plugs tries I usually just let the gp light shut off then try again, like I said a lot of times will act like wants to start each attempt but only for the 1st second or 2, if it don't fire off immediately, it will not until you stop cycle key again. Length of time letting glow plugs run doesnt seem to affect it. Does make quite a bit of grayish smoke while attempting to start.
If you purchased the glow plugs off the internet, they are very likely to be fakes. You can test them where the UVCH plugs in without having to remove the valve covers.
