2016 F-150 5.0 Spark Plug Replacement
I am about to replace the spark plugs on my 2016 F-150 XLT 5.0. It has about 61,500 miles on it and as far as I know the plugs have never been changed. Haven't owned it long, and the CARFAX doesn't reflect a spark plug change, although the prior owner had it serviced regularly at the place he bought it from. The Owners Manual say 100,00, but I think that's a good bit too long. Probably see gas mileage suffering way before then, although right now the truck runs fine, but maybe already getting less than optimal MPG. I plan to buy the plugs below from Amazon of about $100.00. Copied this directly from Amazon. I looked at a u-tube clip or two, and the job doesn't look to be too much of a hassle. Any suggestions or recommendations based on your experience? Thanks in advance.
New Motorcraft SP547 Spark Plug (8 PACK) Finewire Platinum
https://www.ford-trucks.com/articles...helpful-guide/
It is easy to do on the 5.0 other than the truck being so high and the engine being set back a good bit.
Plenty of info about doing it if you search this forum.
And my truck had about 85K. I think the gap was like .060. Agree 100% at being shocked. Sad thing is the new plugs made no noticeable difference in performance or efficiency.
