V10 Overheating
Old May 7, 2026 | 08:15 PM
2157's Avatar
2157
Trailering
V10 Overheating
2000 V10 that will overheat only when towing and going up a hill. Has 244k and I do know it's still the original radiator. Just looking for some information on the first place to check or where to start.
Old May 7, 2026 | 11:24 PM
Vinny G-the EX man's Avatar
Vinny G-the EX man
Has the thermostat been changed, and if so was it changed with a Motorcraft part? Aftermarket thermostats are unreliable and often cause problems. Have you changed your coolant and was the proper type used? Remember coolant doesn’t last forever even if it doesn’t leak out
Old May 8, 2026 | 06:08 AM
Freedom-over-safety's Avatar
Freedom-over-safety
I’d start with the fan clutch. https://www.doityourself.com/stry/ho...t-a-fan-clutch
Do you hear it engage when pulling a hill ?
Old May 8, 2026 | 08:05 AM
LX Sport's Avatar
LX Sport
Check the radiator coil it may need cleaned. The AC condenser coil may look good but you need to check the radiator behind the AC condenser.
Old May 8, 2026 | 09:25 AM
2157's Avatar
2157
Trailering
If it runs at the correct temp other than when towing up hill, could the thermostat still be bad? Coolant will definitely be changed soon.
Old May 8, 2026 | 09:27 AM
2157's Avatar
2157
Trailering
With the fan clutch and it engaging, can't reallly tell since the trans tends to down shift and can't hear the fan clutch.
Old May 8, 2026 | 09:31 AM
2157's Avatar
2157
Trailering
If I do decide to replace the radiator is there one that would be recommended?
Old May 8, 2026 | 12:24 PM
John in OkieLand's Avatar
John in OkieLand
I bought a Murray radiator, seems to be just fine.
Lifetime guarantee from O'Reilly's
Old May 8, 2026 | 01:47 PM
LX Sport's Avatar
LX Sport
Before you replace the radiator, remove the plastic shroud that's on top the radiator and look down between the AC condenser coil and the radiator. I found the front of my radiator was plugged with debris. Cleaning this off the radiator fins fixed my overheating issue.
Old May 8, 2026 | 02:44 PM
2157's Avatar
2157
Trailering
Will have a look at that spot later today. Thanks
Old May 8, 2026 | 03:45 PM
2157's Avatar
2157
Trailering
One more thing, I mostly use this for towing my car trailer and the over heating has never happened before. It was all of the sudden, with the trailer loaded and going up a fairly steep hill that it got hot. Not sure if that matters or not.
Old May 8, 2026 | 03:55 PM
ashleyroachclip's Avatar
ashleyroachclip
Did you happen to check the trailer brakes , see if they might have been dragging ?
Old May 8, 2026 | 03:57 PM
2157's Avatar
2157
Trailering
I did. Seem to be workin g fine.
Old May 8, 2026 | 05:06 PM
01__Excursion's Avatar
01__Excursion
I think it has been mentioned in the past that someones water pump impeller blades had rusted, or worn down significantly causing poor water flow leading to overheating..
Old May 8, 2026 | 05:14 PM
2157's Avatar
2157
Trailering
Nothing in the area between the radiator and condenser.
