What I’ve Learned Maintaining My Super Duty (F-250 / F-350) After Heavy Use
Old Today | 04:59 AM
2026_David%Life's Avatar
2026_David%Life
4th Gear
Hey guys,
Been running my Super Duty mostly for hauling and some towing over the past couple of years, and just wanted to share a few things I’ve learned that might help others — especially if you’re using your truck for real work, not just daily driving.
1. Oil changes matter more than you think
If you're towing or hauling regularly, don’t follow the “normal interval.” I started doing oil changes around every 5k miles instead of stretching it. Trucks under heavy load break oil down faster.
2. Fuel system = expensive mistakes
On diesel trucks, bad fuel or contamination can mess up injectors and even the whole system. Keeping filters fresh (every ~15k miles) has saved me headaches.
3. Keep an eye on front-end wear
If you start seeing uneven tire wear or slight steering vibration, don’t ignore it. Alignment, tie rods, or suspension components can wear out faster on heavy-duty use.
4. Fluids are everything
Transmission, coolant, brake fluid — all of it. These trucks run hot when working hard, and skipping fluid checks can lead to bigger issues later.
5. Don’t skip basic inspections
Tire rotation, brake checks, and quick visual inspections every service interval go a long way in preventing downtime.
Honestly, these trucks are built tough, but they’re not “maintenance-free,” especially if you’re actually using them like a Super Duty should be used 💪
Curious what others here are doing differently — any tips or things you’ve learned the hard way?
Old Today | 06:12 AM
1olddogtwo's Avatar
1olddogtwo
Originally Posted by 2026_David%Life
Hey guys,
We run a fleet from f-150s to 750s, bunch of Yahoo drivers and I'm happy if they don't put gasoline in a diesel.
I would agree with everything you say but we do 7,500 miles intervals on oil changes, 15,000 on fuel/ tire rotations/ inspections.
You missed out on the idling part, I have 15 minute intervals set on the GPS for alerts.
Old Today | 06:36 AM
The Seeker's Avatar
The Seeker
what for oil are you using?
Old Today | 01:55 PM
1olddogtwo's Avatar
1olddogtwo
We use rotella 15-40 out of a drum.
We run that all of our 6.7s, Kenworth's, CAT equipment, and my favorite.......Isuzu trucks, hate those SOBs
Then we recycle and burn it
Old Today | 02:01 PM
Black Buzzard's Avatar
Black Buzzard
OP.......Why this looks like AI-generated text:
  • Overly Clean Structure: The post uses a rigid, bullet-point formula (1, 2, 3, 4, 5) with a clear opening, summary, and closing question. It is far more organized than a typical, quick, stream-of-consciousness forum post.
  • "Corporate Casual" Tone: AI often adopts a "safe," polite, and enthusiastic, yet bland tone (e.g., "...saved me headaches." "...don't ignore it." "...go a long way..."). It lacks unique, slang-heavy personal voice or specific personal anecdotes.
  • Overused AI Phrases: Phrases like "Fluids are everything," "Fuel system = expensive mistakes," or "Honestly, these trucks are built tough" sound authoritative but are very generic.
  • Generic Emojis: Ending with a single relevant emoji ("💪") is a common AI tactic to appear human and casual.
  • Perfect Grammar: Despite being a casual post, there are no typos, missing apostrophes, or awkward phrasing, which is suspicious in a casual forum post.
Old Today | 02:18 PM
CBEllis's Avatar
CBEllis
Maybe he ran his thoughts through an LLM like ChatGPT or Copilot? Or maybe he's an english teacher?
Old Today | 03:21 PM
Isthatahemi's Avatar
Isthatahemi
Post
I was just going to say this is a bunch of platitudes that looks generated by AI.....No original thoughts
Old Today | 05:57 PM
Charlie98's Avatar
Charlie98
When I ran my own truck, I religiously ran Rotella T 15w40, changed every 15000mi. We had it in for a bad injector at about 800K, mechanic said the overhead looked like it had about 200K on it. (N14 Cummins.)
I run Mobil 1 in whatever weight the manufacturer says in my gassers... Ford just happens to like 5w30 for both of my trucks.
Old Today | 06:09 PM
twobelugas's Avatar
twobelugas
It's a bot. See this post
https://www.ford-trucks.com/forums/1...l#post21797338
Bots don't yet know Ford itself is not in the OTR truck business stateside at least directly.
Old Today | 07:03 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
I knew it was! Saw this thread this morning right after he (it) started it and thought something was off...
Boaterguy
6.7L Power Stroke Diesel
47
Jan 16, 2026 06:55 PM
Strokin-A-2010
6.2L V8
25
Sep 28, 2016 08:36 AM
rickgthf
Mar 31, 2008 12:33 AM
Rat wagon
Oil & Lubrication
May 10, 2003 08:25 PM
