Roof track question
Old Mar 29, 2026 | 10:53 AM
speakerfritz's Avatar
speakerfritz
Roof track question
not sure but I might have hidden roof tracks under this mixing which looks like it might just pop off.
Old Mar 29, 2026 | 10:55 AM
speakerfritz
On my bed cap I had done Yakima tracks installed and these cross bars attached to a mount on the Yakima tracks.
Old Mar 29, 2026 | 10:57 AM
speakerfritz
My question is ….are there attach points under my cabin molding for something like the Yakima tracks which would let me use some of my existing cross bars.
thanks
Old Mar 29, 2026 | 11:48 AM
4wd6.7L's Avatar
4wd6.7L
thanks
No, nothing under there intended to be used as mounting points. I could be wrong, but I think the only Yakima racks sold for these trucks are the clamp on style.
Old Mar 29, 2026 | 03:27 PM
svtride's Avatar
svtride
No, that’s called a “ditch molding” it covers the joint for roof to body side stampings. There are no rack tracks under it.
Old Mar 29, 2026 | 03:49 PM
Sport45's Avatar
Sport45
I thought I posted this earlier but it’s not here. Maybe it’s on another thread or I forgot to hit the post reply button…. Anyway, the passenger side cab trim disappeared off my ‘19 quite a while ago. Here are pictures of what the truck looks like underneath.
Lots of bolts there that might be good for something.
Old Mar 29, 2026 | 09:27 PM
speakerfritz
interesting…
thanks
Old Mar 29, 2026 | 09:45 PM
Wangdangdoodle's Avatar
Wangdangdoodle
Does the plastic track just snap onto those studs? I've been wanting to take it off to clean under there.
Old Mar 29, 2026 | 11:06 PM
Sport45's Avatar
Sport45
I don’t know how it comes off. Just noticed mine was gone when I saw a post where someone mentioned the trim coming loose at the back window and I wondered how mine was doing.
Old Mar 30, 2026 | 04:00 AM
speakerfritz
Looks like the answer to my question is yes
under the plastic trim, some of the bolts can be used to mount a roof rack.
i found this install video.
the track I want to use will require a different style mounting setup but this video is encouraging ….if the mounting kit for my track is not out there looks easy to fabricated.
Old Mar 30, 2026 | 04:24 AM
speakerfritz
Another approach
Old Mar 30, 2026 | 12:46 PM
ongrade's Avatar
ongrade
7th Gear
If you remove that molding you will never get it back on unless you buy a new one and remove the rear window to access the mounts for the end of the molding.
Old Mar 30, 2026 | 04:20 PM
speakerfritz
Another senerio using the bolts and no tracks
Old Yesterday | 11:05 PM
speakerfritz
8pack
Sep 29, 2024 09:33 PM
Bassmaster96
Aug 29, 2024 04:11 PM
caleb_ford
18
Jul 12, 2021 02:46 AM
Johnny Mayday
2015 - 2020 F150
Dec 29, 2017 03:09 PM
Maverick1978
1997 - 2003 F150
Oct 15, 2016 03:15 AM
