1976 F500 VIN decode
F50 = F500, chassis and cab
C = 330 2V MD FT gas V8. (Medium Duty = cast 360 crank, FE distributor and oil pump drive, and other FE items)
V = Kentucky Truck Plant
C00429 = 1976 numerical series, April 1976 production
158 = 158 inch wheelbase
T = Candyapple Red
F501 = F500 chassis and cab, 16,000 lbs GVWR
AA8
AA = Black HD vinyl
8 = Regular cab, chassis and cab vehicle.
A = New Process model 435 four speed transmission
41 = Rockwell (Timken) model D-140 single speed rear axle, 13,000 lbs GVWR, 5.83 ratio
No front axle code.
16000 = 16,000 lbs GVWR
22 = Charlotte District Sales Office
No special order.
Note that your warranty tag has been removed and reattached. The Hex head screws are not original. As OEM it would be attached with "tamper evident" rivets.
Check your wheels and make sure they are either tubeless or have a split locking ring evident. Easy to see on the front, but they face each other in the rear.
Any plans for it?
T = Candyapple Red
AA8
AA = Black HD vinyl
No front axle code.
No special order.
Any plans for it?
Also, another fun door tag from the dump bed maker.
Your 330 M/D should pull a load OK, though you are really missing out with your gears. Empty, it should pull 60 MPH on the flat without issue with your current 5.83:1 rear, and if it doesn't then I'd look hard at that engine. I've a 6.17:1 high ratio in mine, and while my 361 is ~10% more displacement than the 330, I can pull 70 empty without issue, though it's loud and running a bit higher on the tach than I'd like.
Loaded, the game's completely different. When you put 6-9k in the back of that, you are going to want more gears or at least a 2-speed in back, or you'll take a long time to get up to speed. But it can still be done. Almost all of our trucks have direct top gear, both the 4-speeds and 5-speeds, and the OD boxes are rare to find and snapped up for repowers etc.
If you think you need a 3208 to get your work done, if I was starting with a 4-speed box and single-speed rear, I think I'd look hard at starting over with a more capable base truck, yeah. The diesel will get you better mileage, but with today's price split on petrol vs diesel, the diesel may not save much on running costs, and if you're driving a 50-year-old truck enough to sweat the running costs, you should be in a newer truck with modern brakes anyway, lol.
[later]
Sorry, I missed this:
If you're already rowing gears 2-5 then IDK how much having 2-speed rear axle will help. Do you feel that the engine is running well? Timing around 6-10° BTDC? All cylinders contributing? Consider doing a cylinder balance test. On a rig this old, the cheapest way is to use fiberglass pliers to remove each plug wire in turn from the dist cap (not from the plug) while the engine is running at a steady 1000-1200 RPM via the hand throttle cable, and noting the RPM drop when you disconnect each cylinder; each one should cause about the same RPM drop. If you pull a wire and the RPM doesn't drop, you found a dead hole. Plug, valves, or broken ring are the usual suspects, if you're testing at over 1k RPM. Below that, vacuum leaks can also cause lack of firing.
You don't want to pull the wire from the spark plug, because then you're holding a live wire whose trying hard to fire to ground, and it will find any weakness (like dirt on your pliers, up your arm) to so so. Pull the wires from the dist cap, you're holding a dead wire and won't have that to worry about.
