1965 vs 1968 F250 Front Spindle
I was going to post a link to Fordification but the site is temporarily down. There are always differences so the best route is to get everything from a donor truck, "I" beams with the spindles, steering linkage, brake proportioning valve, brackets for the rubber lines and the booster/master with the brake pedal.
Any disc brake F250 up to 1979 will work if you get everything from it.
x2 what @Crop Duster said.
1965 F250 2WD which only came with the 12 1/8" x 2" drum brakes would have different spindles than a 1968 F250. Only if you have a 1966 F250 2WD with the heavy duty 12" x 2 1/2" drum brakes (not the 12 1/8" x 2") would they be compatible.
flipklos
06-09-2009 06:09 PM
lasthighboy
02-03-2008 02:28 PM
MrHomz
01-03-2008 07:16 AM
