New 96’ f150 running lean and stalling
Hello All!
I just got a new 96’ f150 and its my first gas truck and i have some issues that I wanted to get your opinions on. So i’m getting a lean code and bank codes, with a MAF code as the cherry on top. The issue at the present is that when I start it I gotta let it beep three time, crank it up, then you gotta rlly give it some gas or once you get going a little it’ll stall out. But after it warms up it has a really rough idle, when I stop at a light or something and about to come to a complete stop, itll shutter a lil and just starts shakin. I assumed it was a fuel pump so I switched between tanks to see if one was better than the other, but they both performed the same, threw some sea foam in there to see if that would do anything. I’m hesitant to say it’s the fuel pump, due to both working about the same, I took a look at the fuel filter and it looked relatively new, but i got one on order just to be safe. I’ve also got a new MAF coming in today to see if that’s the solution, but outside of that i’m not quite sure what it could be. Any words of advice would be super helpful!
edit: Oh and the EGR diaphragm has been replaced recently and so has the Idle air controller.
Received 1,032 Likes
on
Last owner said there was an exhaust leak, I can hear it but haven’t pinpointed it yet. Could that cause an issue this bad?
Codes are p0171 p0102 p0113 and p0174
Codes are
Well after further investigation it seems that the previous owner has removed the cats entirely for some reason, he also took what I assume is the EGR tube and welded it closed and onto the new pipes. I assume this is the cause of my issue.
on
Correct me if I'm wrong, but wouldn't fresh air being pulled over the O2 cause it to run richer? Because it would think it's running lean, and try to compensate with more fuel?
on
You would think right... but somehow it trends the other way. I think it's because the computer is actually seeing the rich-lean pulses and perhaps when it goes rich it's way too rich which then forces it to pull out even more fuel and overall the engine ends up too lean.
We'll see where he's at with the new MAF.
I thought I could escape my vacuum leaks by switching bmw to ford, but was I ever wrong.
