87 F150 4.9 No injector pulse, No fuel pump power
I have an engine I pulled from an 87 Ford F150 (harness and all) that I put in a 73 F350. I got it in the truck but have no injector pulse, and the fuel pumps aren't kicking on. Fuel pumps work if hotwired, and engine runs if injectors are manually pulsed. The 87 is a dual tank model with three pumps but I'm only using the side tank and frame pump. I did go through the harness and eliminated what I assumed was unnecessary wiring (mainly interior) but I don't know if there may have been something that would have this effect. All grounds that I can find have been tested and come back grounded. I tried checking my dad's 90 F150 but his harness has different connections. I'm unsure what to check next and would appreciate any advice or things to check.
Pins 40 and 60 at the computer need to be connected to ground. On '87 through '89's, the two wires to the battery negative terminal were how that was accomplished.
I'll have to double check thursday and see if those were both grounded
Have you tried checking for codes? That will tell you if the computer is powering up and can communicate through the diagnostic test port.
I don’t know what you unnecessary wiring you eliminated for the interior because the engine harness does not have anything to do with the interior other than the wires from the engine sending units to the instrument cluster.
I don't have a standard instrument cluster to attach to so nothing interior wise would have an effect, correct?
This may be my issue, I went and got the harness today and don't remember having the connector those go to connected to anything. I won't know for certain for a couple weeks when it all goes back together. Is there a reliable diagram for the computer?
viavr
02-24-2018 11:20 PM
