Transmission fluid on heat exchanger
So, saw some drip marks on driveway. Looked under truck. The bottom of the heat exchanger between the oil pan and transmission pan was wet with transmission fluid.
Any ideas?
I cleaned it off and will see if it repeats. Need to do an oil change in about 600 miles anyway.
2022 7.3 w 10R140
Any ideas?
2022 7.3 w 10R140
I have an appointment next week (during my vacation).
I will swing by dealer this afternoon and discuss and maybe they can get parts before next week. I would rather not be without truck for extended period (hard to tow boat with wife’s car).
And driving it without a dipstick to keep an eye on the levels is not a comfortable feeling either.
I had fluid as high as the top of my starter and it was the torque converter seal. They had to drop the trans and refill with fluid. Kinda sad that starts leaking by 30k miles. I had high hopes for my trans because it is supposedly built post-CDF drum fix. I dont beat on my truck and still take it easy while towing so I suspect we will see a lot more of these leaks as people put more miles on these. Definitely a PITA if you have to do this repair at home or on your own dime.
Well, went by the dealer today. I have an appointment on 5/16. Sucks that I will be without truck during my vacation. Anyway, they said that they see more torque convertor seals than transmission cooler leaks.
And they said that appointment on Thursday doesn't mean that they will get to it on Thursday. Anyway, my skid plate will have to come off and then they can clean it up, drive it, and see if they can find where leak is coming from.
I cleaned the cover for the cooler/heat exchanger off last night and it is very wet again this afternoon after 50 miles. If I didn't have the skid plate installed, I would remove the cover to see if I could see more of the leak.
So, minimal driving till I get it to dealer since there is no way to tell how low I am on fluid.
Hope they can fix quickly.
Money-Pit
11-17-2013 05:45 PM
chas31310
22
09-05-2006 05:03 PM
