Play in Pully?
Play in Pully?
Hello,
I have a 2000 E250. While driving the belt must have come off and got shredded. As i parked the van overheat and I believe it's antifreeze that went everywhere. I checked the pullies where the belt goes and I have a little bit of up and down play in the water pump. Is this normal? The other pullies don't seem to have any up and down play at all.
Thanks!
Butch
Thanks!
Butch
Thanks for the reply. I'm thinking the belt just broke and the engine overheated. The pully on the water pump has just the smallest amount of play. I can't see it move but I can feel a slight bit of play lifting up and down on the pully. It doesn't make any noise and it is smooth to turn. When I spin it it feels solid. I'm wondering if the antifreeze was just overflow from the heated engine. I could hear bubbling when shut off the engine. I put a new belt on and filled the radiator. I drove it a short distance and it didn't overheat and the coolant level remain steady.
Thanks. I figured I'd need to replace the pump. I'm not sure what the condition of the belt was before it came off. When I looked at it, it was in pieces and wrapped around the fan shaft. It had shredded lengthwise.
If you are lucky, it just shredded the old belt, and you can replace the water pump or other pulleys later
Usually, those idler and tensioner pulleys squeal like a stuck pig when the bearings start to fail
If you heard no noise until the belt went, you might be okay for a while
Have fun, good luck
Trust your original work and the water pump should start to leak coolant when the bearing gets loose enough to ruin the seal
Have fun, good luck
Have fun, good luck
Have fun, good luck
fatso123
07-03-2004 04:37 PM
peppep
03-18-2004 08:21 PM
centaurld
03-11-2004 11:42 AM
