1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Slightly bigger tires
Old 02-19-2019, 09:22 PM
Rob89's Avatar
Rob89
Rob89 is offline
Hey guys. My truck is a 16 F-250 CCSB Lariat 4x4 6.2 with 3.73 gears. I have the 275-65-20 Michelin’s which are great tires. They are 34.07 inches tall and 10.83 inches wide. I have 33k miles on them and have roughly half tread life remaining. I am thinking of going to 295’s which are 35.1 inches tall and 11.61 inches wide. They would bring my 3.73 to an effective 3.62. Has anyone made this slight bump in tire size and do you think it would be very noticeable?
Old 02-20-2019, 05:49 AM
don123's Avatar
don123
don123 is offline
A few guys on here I see running a 35” tire with 3.73 gears towing 8 to 10k trailers without any problems. 4.30’s would be optimal even 4.56 gears according to some.
Old 02-20-2019, 06:38 AM
Rob89's Avatar
Rob89
Rob89 is offline
Thanks. I’m planning for a travel trailer in the 8-10k range eventually so that would be my main concern. I think unloaded and towing my utility trailer around here and there at 2-5k wouldn’t make much of any difference.
Old 02-20-2019, 07:43 AM
jav_eee's Avatar
jav_eee
jav_eee is offline
Just FYI the 295 number you mentioned wanting to go up to is actually the width of the tire. The second number (for 295 I'd say 65 would get you 35" tall) is the height.
Old 02-20-2019, 07:47 AM
Rob89's Avatar
Rob89
Rob89 is offline
You are correct.
A 275-65-20 is 34.07 inches tall. A 295-65-20 is 35.1 inches tall. My concern is about how the extra 1.03 inches of tire height will affect the drivability of my 3.73 gears.
Old 02-20-2019, 09:45 AM
RainDesert's Avatar
RainDesert
RainDesert is offline
I would go with a lighter weight tire if you can, adding the additional height and a heavy mud tire would have more effect. Jumping up in size will not make the difference of losing a gear or anything with 8k behind you. You still won't be using 6th and have to use 3rd quite a bit on any hwy grade.
Old 02-20-2019, 10:11 AM
redford's Avatar
redford
redford is offline
Received 1,565 Likes on 913 Posts
Your effective differential ratio with the new tires will be 3.62:1.
Not terrible, but you'll notice the difference.
Old 02-20-2019, 05:13 PM
Chuckfx4350's Avatar
Chuckfx4350
Chuckfx4350 is offline
How did you figure out what your gear ratio would change to with larger tires?
Old 02-20-2019, 05:47 PM
Rob89's Avatar
Rob89
Rob89 is offline
Google. Just search for a gear ratio calculator. Enter your old and new tire diameters and trucks gear ratio and it tells you what your new effective gear ratio is with the new tire diameter.
Old 02-20-2019, 06:01 PM
Chuckfx4350
Thanks! So where are you in South Florida? I’m in Fort Myers/Naples area
Old 02-20-2019, 06:56 PM
Rob89's Avatar
Rob89
Rob89 is offline
I love it over on that side of the state! I was in West Palm Beach until September of 2017. I’m now in North Carolina in the foothills of the Blue Ridge Mountains. I love the way of life up here however I do long for palm trees every now and then!
Old 02-21-2019, 02:19 AM
YatzeK's Avatar
YatzeK
YatzeK is offline
It just won't
Only if you really focus on it - it's less than 3% difference so you may (or may even not) actually feel it on the first few miles on new tires only. And stop even thinking of it right after
Old 02-21-2019, 10:49 AM
Batman7777's Avatar
Batman7777
Batman7777 is offline
Shift points will change, but maybe not much. You don't want rear diffs with a 3.73 to shift too early as it would add additional stress to the drive train.
The same as shifting to a higher gear on a 10 speed bike (Going into 10th gear) before you have enough speed to accommodate (Lots of drag).
KING-RANCH02
1997 - 2003 F150
04-21-2015 10:02 PM
relaurain
01-12-2012 10:23 AM
Dads79
05-16-2010 08:30 AM
cabloom300
29
11-06-2009 02:48 AM
Sycostang67
01-27-2005 09:38 PM
Quick Reply: Slightly bigger tires
