Slightly bigger tires
Hey guys. My truck is a 16 F-250 CCSB Lariat 4x4 6.2 with 3.73 gears. I have the 275-65-20 Michelin’s which are great tires. They are 34.07 inches tall and 10.83 inches wide. I have 33k miles on them and have roughly half tread life remaining. I am thinking of going to 295’s which are 35.1 inches tall and 11.61 inches wide. They would bring my 3.73 to an effective 3.62. Has anyone made this slight bump in tire size and do you think it would be very noticeable?
A 275-65-20 is 34.07 inches tall. A 295-65-20 is 35.1 inches tall. My concern is about how the extra 1.03 inches of tire height will affect the drivability of my 3.73 gears.
I would go with a lighter weight tire if you can, adding the additional height and a heavy mud tire would have more effect. Jumping up in size will not make the difference of losing a gear or anything with 8k behind you. You still won't be using 6th and have to use 3rd quite a bit on any hwy grade.
Google. Just search for a gear ratio calculator. Enter your old and new tire diameters and trucks gear ratio and it tells you what your new effective gear ratio is with the new tire diameter.
I love it over on that side of the state! I was in West Palm Beach until September of 2017. I’m now in North Carolina in the foothills of the Blue Ridge Mountains. I love the way of life up here however I do long for palm trees every now and then!
Only if you really focus on it - it's less than 3% difference so you may (or may even not) actually feel it on the first few miles on new tires only. And stop even thinking of it right after
Shift points will change, but maybe not much. You don't want rear diffs with a 3.73 to shift too early as it would add additional stress to the drive train.
The same as shifting to a higher gear on a 10 speed bike (Going into 10th gear) before you have enough speed to accommodate (Lots of drag).
relaurain
1999 to 2016 Super Duty
01-12-2012 10:23 AM
Sycostang67
01-27-2005 09:38 PM
