Firewall mounted brake bracket
Received 4,135 Likes
on
on
on
Classic Car and Truck Brake, Steering and Suspension Parts
1953-56 Ford F-100 Firewall Mount Prevalved, Disc-drum
Here's the link to both of them, if you enlarge the picture on the Midfifty site you can read the CPP sticker on the proportioning valve
on
That link for CPP I believe is what you are asking for Pappy, bracket and pedal, it's $149. If you purchase it with the booster and master cylinder, proportioning valve it's $299 They just use the same picture for description. Give them a call and tell them what you're after. Might be better going with the complete package rather than using used parts
Hey bjmaybery2 I picked up a cab in great shape it does need some finish work done and a few holes need welded up. Not what someone was thinking. Been too cold here to do much on it my garage is not heated. Going to pick up some things I will need to put it back together once I get the cab done. I need some inner fender wells. Going to try and repair the fenders and the valance
#1spudman
07-25-2016 04:13 PM
atlantaf100
10-10-2001 12:18 PM
