Tire size question
Depends on how you feel about rub and how different your wheel offset is from Oem. I’m not the resident expert on offset and backspacing. 35’s fit easy. 37’s will rub between 37 and 40 degrees of steering angle (the last 3 degrees of turn to full lock) with oem offset. Many on here are running 37’s with minor rub and using our brains to compensate. I’m ok with it because there is absolutely no body rub or other contact. I will be replacing my radius arms and sway bar in the spring to eliminate rub.
Here is my setup with 37’s, no lift:
These black rhino's are 20x9.5 with a 12 offset. The tires are 37x12.5 and do rub the radius arm just slightly at full lock.
These are Cooper AT/3's 285/75r18 on the stock XLT wheels 18x8 44 offset. They did not rub at all.
These are NITTO 37x11.5 on the stock platinum wheel 20x8 44 offset. They do rub at full lock.
how do you like those tires? I had them on my Tacoma before upgrading to the F250. I hate the goodyears that came on the truck. no traction in the mud or snow
Thanks ahead of time!
Rod27
2017+ Super Duty
19
07-24-2019 09:50 PM
