Np435 input shafts
Old 09-18-2018, 10:04 AM
jason832's Avatar
jason832
jason832 is offline
Np435 input shafts
I have two np435's. Trans A needs a rebuild and has the input shaft for the 300. Trans B appears to be in good shape and has the larger FE input shaft. Can the input shaft of A be put on B?
I can investigate as I have one of each trans out of the truck if need be.
Old 09-18-2018, 11:19 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
No such thing.
What year/model trucks are the NP435's from?
Old 09-18-2018, 11:42 AM
jason832's Avatar
jason832
jason832 is offline
I don't know the exact years they came out of but the FE was mid 70s or so and the small block 80-86. I can try to identify them better tonight if the year can be determined that way as well.
Old 09-19-2018, 09:22 AM
jason832's Avatar
jason832
jason832 is offline
Tried to grab she pictures this morning. Note the difference in bellhousings and the slight difference on the input shafts. I'll try and put a 300 clutch disc over it tonight and see of they are indeed different or not, but they are visually different when comparing the two side by side.
Small block
​​​​​​other np435
Old 09-19-2018, 03:07 PM
FuzzFace2's Avatar
FuzzFace2
FuzzFace2 is online now
Received 2,108 Likes on 1,796 Posts
You want to measure between the two:
The spline count, try the clutch disc on both.
The spline is the same distance from trany face out.
The pilot bearing area is the same on both and same dia.
The front bearing retainer or throw out bearing sleeve is the same dia. and how long each one is.
I cant see them making different in put shafts for different size motors within the same manf.
Now if 1 trany was a Ford and the other a Dodge then I can see the in put shafts being different.
Bell housings should just unbolt.
BTW check if the trany to bell bolts are the same distance on both.
Dave ----
gravydude
WTB - Parts & other
09-28-2016 11:29 AM
Oldsman003
2004 - 2008 F150
03-22-2016 12:21 PM
vntgtrk
11-16-2012 04:15 PM
yotee
Offroad & 4x4
04-11-2010 04:47 PM
DJOHNSTON78
05-14-2008 11:59 PM
Quick Reply: Np435 input shafts
