After Market Intercoolers?
Just blew out my stock intercooler towing less than 3500 lbs. at about 60mph. Sooo I am trying to find out what any of you with after market intercoolers think would be the best replacement one. Or anybody with a thought about the best one. The hype and prices are all over the place. The truck only has 90k miles on it.
Thanks for any input here.
first question we would have for you is which intercooler are you referring to? as this truck has a few of them.. Oil, air, and transmission has one before reaching the external cooler. if your referring to the engine oil L2L intercooler, most will recommend the factory upgrade version.. the transimission intercooler is built into the bottom of the radiator before passing onto the external one (factory radiators fine but some upgrade to michimoto).. the Intake air cooler, can depend.. the plastic end caps are known for failing but is still a good option. Michimoto, Banks, AFE and BD diesel all offer aftermarket ones. i havent heard much on BD diesels version but i wouldnt buy from them anyways as i could never get an answer out of them when i tried asking on some of their other products.
Thanks Sparky83. Yes it is the intake air intercooler and yes the plastic end blew off. So I don't have much faith in the oem ones anymore. Just looking to see if someone has had good or bad experiences the brands you mentioned. I do have an oem one in it now that I got used from a wrecking yard. Physically it is in very good condition, but?
Thanks again.
Thanks again.
Thanks again.
Thanks again.
I installed a CSF 6013. It's an all aluminum welded intercooler with the same tube and fin design as the stock intercooler. They also make a 6028 which is a bar and plate design. Supposedly more efficient but also doesn't allow as much air flow to get to the radiator. Either one I think would be a suitable replacement and an upgrade from the factory intercooler as far as durability is concerned.
I pressure tested mine mine just because it was a returned cosmetic damage one and had a dent. Tested fine and got it for $90. I think a new unblemished one would be good to go. Easy enough to pull if you find it has a boost leak.
FTE Herman
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
03-19-2006 08:03 PM
