410 Build Calculation Check
Old 06-19-2018, 04:14 PM
WentzMetalWorks's Avatar
WentzMetalWorks
WentzMetalWorks is offline
Hello All,
I'm currently putting parts together for a 410 to put in a 73 HighBoy. I have a 352 block that I've had bored to 4.050 ready to go. I just want to make sure everything I have is going to work and double check my math.
428 1U Crank - 3.984" Stroke
C3AE-C Rods - 6.49" Length
Silv-O-Lite 1139 Pistons - 1.66" Comp Height
Deck Height 10.17"
That combo should put me at 10.142", so .028" below deck.
With Cometic 0.080 head gaskets and Edelbrock RPM Heads, I should be running about 9.5 to 1 compression.
Also, what cam profile and carb would you guys suggest? Any input would be much appreciated.
Thanks,
Keegan
Old 06-20-2018, 07:36 AM
krewat's Avatar
krewat
krewat is offline
Site Administrator
Someone will be along shortly to help you spend your money
Old 06-20-2018, 12:20 PM
MIKES 68 F100's Avatar
MIKES 68 F100
MIKES 68 F100 is offline
Question is what do you want from truck ? drag racing , towing , weekend fun or tire destroyer ?
Old 06-20-2018, 11:48 PM
WentzMetalWorks
It will be a daily driver/weekend warrior. No towing save a 10 foot smoker. No racing save red light to red light. Something that’s somewhat drivable on the street but can pack a punch when you push the go pedal. Emphasis on torque.
Old 06-20-2018, 11:49 PM
WentzMetalWorks
Also, the plan is to swap an NV4500 into it as well.
Old 06-21-2018, 08:54 AM
MIKES 68 F100
I am a fan of lunati cams ,made in the USA! the 62002 would probably get you in the 500hp/500tq area .
what intake ,carb and exhaust you going to run? i'll do a Desktop dyno of your specs .
Old 06-21-2018, 10:11 AM
krewat's Avatar
krewat
krewat is offline
Site Administrator
Originally Posted by WentzMetalWorks
Emphasis on torque.
You need a roller cam
(money spending commences)
Old 06-21-2018, 10:13 AM
MIKES 68 F100
roller would be nice , but not everyone has deep pockets
Old 06-21-2018, 10:39 AM
krewat's Avatar
krewat
krewat is offline
Site Administrator
Hence my statement above
Old 06-22-2018, 08:42 AM
MIKES 68 F100
Didn't get to run the DD5 sim last night SWMBO had me running in circles with house stuff when i got home . I'll run it tonight .
Old 06-22-2018, 07:04 PM
MIKES 68 F100
ok I ran 2 sims with eddy performer RPM intake and 750cfm carb
run 1 with 62002 cam
run 2 with 62003 cam
RUN 1 62002
RUN 2 62003
Old 06-23-2018, 08:24 AM
Destroked 450's Avatar
Destroked 450
Destroked 450 is online now
The 62002 makes more power and torque up to 4000 rpm than the 62003
The average driver won't notice the extra 18 hp at 5000 rpm, but they would notice that extra 20+ lb ft torque from idle to 2500 rpm where they would spend a lot of time at
Run a sim with the 62001 cam and see if it gets the numbers down into a more useable rpm range, I've won a lot of races on the hole shot.
Old 06-23-2018, 06:14 PM
MIKES 68 F100
here's the 62001 run
i have the 62001 in my 390 it runs strong but doesn't have much of a choppy idle . If i were to do it again i would go with the 62002
62001
Old 06-23-2018, 10:21 PM
Destroked 450
Looks like the 62001 gives up a good bit on top without much gain down low.
I'm surprised there's that much difference.
Just for comparison would you run Lunati's 10503 cam, that's their version of the factory 428CJ cam
It should give one a good base line to compare other cams to.
1972RedNeck's Avatar
1972RedNeck
1972RedNeck is offline
62002 looks like the best to me.
Roller would be nice though. How much more would you realistically get with a roller cam?
Quick Reply: 410 Build Calculation Check
