"Wrench" dash icon
"Wrench" dash icon
I had my truck out today with 3 stops. After the third one the wrench icon was lite up on the dash. Nothing seemed to be wrong. Said check manual, first was 4 wheel drive which I don't have. Second one I found in the book was emissions.
I decided to take off the oil separator lines and put on the stock one (cleaned out the oil while I was there too) with the stock line one the icon light went out on start up. Put the oil separator lines back on and still no light. The oil separator has been on for 6 months and 8000 miles. I can't see it being the problem. Any ideas?
When the light came up and went out after you swapped the oil lines, there should be a code in the system so maybe that`ll give you more info on what the problem really was or is.
I believe AutoZone will check it for free.
I hope this helps you out.
The wrench icon came on my truck when it had about 8K miles on it. The owners manual for the 2015 has absolutely nothing in it about the wrench icon. Mine turned out to be a defective throttle body. Which, of course, they had to order. Had to get a rental. Was not happy. But. That is the only issue I Have had with this truck in the 53K miles I've had it.
Good luck.
Good luck.
