Bully!
Bully!
Never really liked the nerf bars I put on the brown truck. They were generic fit DeeZee units which were frame mounted and telescopic. They never gave me a secure feeling-every time I stepped on them, they’d flex, and I was worried that one day they’d simply give way.
Anyway, I pulled those suckers off and installed a set of Bully steps. They seem super solid-no flex-and I feel secure stepping on them
I like em!
I like em!
Do the Bully steps bolt thru the rocker panel?
If so check to see if the rocker panel flex’s at all.
I like the steps and my truck had a set on it when I bought it. Wasn’t the bully brand but similar. What I didn’t like about mine was they bolted thru the rocker panel area and it would flex a little when you stepped on it. So when I had the truck repainted I had them removed and the holes welded up.
I found a set of new in the box nerf bars/steps for a ‘80 to ‘96 F150 I think was the years. I made new mounts for the tubes to fit my ‘77 and didn’t have to drill the frame or nothing and are super solid.
Photos!
Forward mount
Rear mount
Back side
Outside, from underneath
Installation was super easy-drilled four holes. I did snap off a bolt when torquing down, but I plan to replace the hardware with cad plated grade 8
Also, no flex! Even when I throw my (near 300 lb) self up there it’s rock solid. Very happy with them so far
Forward mount
Rear mount
Back side
1) applied to the floor of the cab
2) is inclined to push the top out
I’ve read other reviews here of men approaching 300 lbs using these steps without flex. As long as the bottom of the cab and the rockers are in good shape, you should be ok.
Four inches of lift and 35s might change your attack angle a bit, but I think you’ll likely be ok
I've been debating whether or not to get steps or bars for my Bronco, but my concern is less about looks and more about whether or not I'd get them hung up on something while wheeling and rip them and whatever they're attached to off the rig. I don't really need help getting in, but my wife (5'1") and kids do, so for now I hoist them in myself.
I have the same steps on mine. They only hang down 3-4 inches max. I can measure when I get home if nobody beats me to it.
As for those who are worried about how solid they are- my brother is 425+ lbs and they held up fine. The sheet metal seam they bolt to is two layers thick plus the bend at the bottom of the seam gives it even more strength.
Roger T. Pipe
08-14-2012 09:16 PM
