2018 F250 Front End Wire Vulnerability - READ BEFORE GOING OFF ROAD!!
So last night i'm out at the range setting up targets at 400 yrd. I turn the truck around and drive back to the bench, when I get back I noticed that I was dragging a few sticks under the front lip. (Air dam) I pulled the sticks out and got back to shooting as I was losing daylight but when I got home I looked to see what the sticks could have been caught on. To my surprise Ford has installed the wire harness for the front fog lights and the radar on the drivers side front bumper about 8 to 10 inches off the ground on the back side of the air dam. (see pics below) I am not under some allusion that an F250 with a 6.7 be a mud bogging rock bouncer but I would like to think that an f250 with a 6.7 and FX4 would be able to drive through a field of short brush less than 12 inches tall without ripping wires harnesses out of the truck!!! The last pic is what I did to try and remedy the issue. Hope this helps anyone avoid a costly repair over a design flaw that can be easily fixed.
Factory fog light wire location
Second photo of drivers side fog lights wiring
Relocated wire best I could without cutting. Just used zip ties to move away from heat, any sharp objects. Moved as high as I could without pulling on any wires.
Second photo after wires moved out of the way.
Received 6,707 Likes
on
Adding cable reroute to my list of things to tweak on the truck. I'll eventually get around to that item on my list sometime in 2020.
Go down a dark road in a Prius in WV, and you're going to get loved tenderly. Out of work coal miners absolutely love Prius owners.
FordTruckfan89
15
10-22-2015 07:51 PM
TrailTech
Electrical Systems/Wiring
04-04-2010 06:48 PM
