Question on Ford accessory stowaway rims ramps - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > 2017+ Super Duty
Reload this Page >
2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
Old 04-19-2018, 09:43 PM
Drew5150's Avatar
Drew5150
Drew5150 is offline
Drew5150 is starting off with a positive reputation.
Has anyone purchased the Ford accessory stowaway ramps? I like the fact they can stow away in bed of truck, just not sure they are worth that kind of money.
Old 04-19-2018, 10:09 PM
12Farmer's Avatar
12Farmer
12Farmer is online now
12Farmer is starting off with a positive reputation.
I didn't get many responses back when I asked about these in January, but here's what was in that thread http://www.ford-trucks.com/forums/15...ing-ramps.html. By the way, I went ahead and ordered them on my truck, just don't have it quite yet. Maybe in a couple of weeks, as its getting the spray-in bedliner at GFX this week.
Old 04-20-2018, 01:13 AM
Drew5150's Avatar
Drew5150
Drew5150 is offline
thxs, let me know when you get them!
Old 04-20-2018, 03:40 AM
SnoqMark's Avatar
SnoqMark
SnoqMark is offline
SnoqMark is starting off with a positive reputation.
Also curious about these
Old 04-20-2018, 04:33 AM
Screamingbear's Avatar
Screamingbear
Screamingbear is offline
Screamingbear has a good reputation on FTE.Screamingbear has a good reputation on FTE.
Had them
I had them in my 2015 F-150.
They are very sturdy, high quality, and come with a very robust cable lock system to keep them from becoming someone else's ramps. They mount to the bed walls with very sturdy mounts. If you wish to have a tonneau cover they do create clearance issues, depending on the cover.
if you need ramps, you will not regret ordering these.
Old 04-20-2018, 06:40 AM
Scud67's Avatar
Scud67
Scud67 is offline
Scud67 is starting off with a positive reputation.
I have them in my truck - they handle 800 lbs each. Nice that they stow along the bed wall so they don't take up any space on the floor of the bed. Also, the cables are keyed to your ignition key - which is nice.
Old 04-20-2018, 06:47 AM
Scud67's Avatar
Scud67
Scud67 is offline
And then I installed my top side tool boxes. The ramps are still accessible and out of the way!
Old 04-20-2018, 07:29 AM
Drew5150's Avatar
Drew5150
Drew5150 is offline
what is the measurement from top of ramps to top of bed, I have backflip mx4 cover. Not sure they will fit by the way it looks. Thxs
Old 04-20-2018, 08:58 AM
SnoqMark's Avatar
SnoqMark
SnoqMark is offline
Also, are the brackets that hold the ramps adjustable (up/down)? Like Drew5150 I think this will interfere with my tonneau cover brackets unless I can modify the hanger brackets to be positioned lower.
Old 04-20-2018, 10:27 AM
h2oz
h2oz is offline
h2oz is starting off with a positive reputation.
I have some for sale here... came with truck, never used.
https://www.ford-trucks.com/forums/market/1535176
Old 04-20-2018, 06:58 PM
Screamingbear
Not
The brackets are made of heavy gage fabricated aluminium, they mount to the Boxlink attachment points, and they are not adjustable for height.
Modifications to the brackets would take some doing, and you would need the ability to weld aluminum.
I am not sure how much you could lower them anyway, because there is not a lot of clearance above the wheel wells as I recall.
Old 04-20-2018, 07:02 PM
SnoqMark's Avatar
SnoqMark
SnoqMark is offline
Thanks that helps!
Old 04-20-2018, 08:37 PM
Section179
Section179 is offline
Section179 is starting off with a positive reputation.
Has anybody worked out a bed cover that mounts with these OK? Is it the stowaway position or the tailgate bracket that interferes with the bed cover?
cheers,
section
Old 04-20-2018, 08:55 PM
Screamingbear
cheers,
section
The tailgate plate is no issue at all.
The ramps themselves are a problem when in the stowed position for any type of tonneau cover that extends below the bed rails.
Any tonneau system that sits entirely above the bed rails should not be a problem.
Old 04-21-2018, 07:27 AM
Scud67's Avatar
Scud67
Scud67 is offline
There is only an inch or so to the top of the bed rail. Below you might be able to drop them about 2 inches - if you could modify the brackets (or make your own). I have enough room to remove the ramps with my tool boxes on without trouble. I think the bed covers may be a problem if they have a center clamp - the end clamps both front and rear should not be an issue. You can see the tailgate anchor plate in the photo. No issues with that contacting bed covers.
Quick Reply: Question on Ford accessory stowaway rims ramps
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
