2006 Lariat throttle issue
Hi Guys,
I've the some issue with my 2006 f150 lariat.
Before cleaning the throttle body i have faced the engine hesitation from 1800~2200rpm (NO reaction).
After having cleaned,
Engine start but no response at all on throttle pedal (but can hear that the clap inside of the throttle is activated several times "open ,closed very fast) .
Then Engine light pop up (safe mode activated, but cannot read the error code with my OBD).
Found some values as below:
Ohms between pin #4 & #14 --> 0 ohm instead of 60 Ohms
#16 --> 12 volts = ok
Can any body help?
KR
Yilmaz
Can any body help?
KR
Yilmaz
No sense trying to repair a bad throttle body
They are subject to failure . The gas pedal sends signal to pcm ,pcm sends coded signal to circuit board on motor on side of throttle body ,tps reports where throttle is at back to pcm ,any mismatch and it shuts down .
New throttle body for the revised model was running around $200 oem on ebay. Mine was replaced 100k ago by me seems there was a bad series of them around 05 . I tried a tps and cleaning but it kept failing . No amount of cleaning or testing is going to fix a bad one .
