Which type of trans fluid
The Haynes repair manual IS a mistake. I do not trust it for anything beyond lining a bird cage.
If you want a useful manual look at http://www.helminc.com/helm/homepage.asp?r=
If you want a useful manual look at Service Manuals, Owner Manuals, Wiring Diagrams, Service Bulletins - Helm Incorporated
and what might happen when they "MIX".
Valvoline Maxlife ATF is good for LV applications, reasonably priced at just about every Walmart you could find.
Merc V is an upgrade of the old Dex/Merc type fluids. It starts around 7.3cSt vis. The LV is the low viscosity version of said fluids. While not exactly identical, it's darn close enough that your trans won't know the difference. Hence why Maxlife covers all those specs with one fluid.
when I did my trans oil change just 5k ago I used Mercon LV, dealer confirmed the amount and using LV, also there is a great youtube video about changing it, and LV also expands when it heats up, so make sure to fill it most of the way and then check the level and keep addng it when the trans is warm.
https://www.amazon.com/Motorcraft-ME...ords=mercon+lv
https://www.youtube.com/watch?v=uSEt...d8uc219LbRxAg1
