If my day time running lights stay on when I pull the headlight switch even after I push switch in could it be my drl module and can this cause my truck to not fire up
I think what hes trying to ask is, if his DRL's are staying on after he shuts the lights and key off, will that kill the battery. If you have DRL, you may have the courtesy light where they stay on a few minutes after. Grammar and punctuation really do go a long ways when trying to convey a point or question though.
Crew cab 7.3 idi turbo won't start and all light stay on
When I go to turn my key nothing happens at all my dash lights up as it should and I can hear my glow plug relay clicking but there is no crank at all. but there is power to the starter solenoid because I can fire the truck up with a screw driver. My glow plug and starter solenoid are both new but I have my suspensions about the glow plug wireing harness being bad dose this harness send power directly from ignition to the starting solenoid? And my ignition switch is also new
And when I pull my headlight switch out every light that is supposed to come on dose but when I push it back in they all stay on. I was told it could be a bad DRL but since they stay on after I let my truck run I disconnect the battery because my truck battery will die. Before this all happened the truck would start in half a crank and still dose when I jump it at the starter solinoid
