Day time running lights
Old Jan 23, 2018 | 02:23 PM
79ford351m's Avatar
79ford351m
Trailering
If my day time running lights stay on when I pull the headlight switch even after I push switch in could it be my drl module and can this cause my truck to not fire up
Old Jan 23, 2018 | 09:47 PM
madpogue's Avatar
madpogue
What year truck? Canada-bound model, presumably? What does "not fire up" mean? It's not cranking? Cranking but not starting?
Old Jan 24, 2018 | 03:44 AM
hairyboxnoogle's Avatar
hairyboxnoogle
I think what hes trying to ask is, if his DRL's are staying on after he shuts the lights and key off, will that kill the battery. If you have DRL, you may have the courtesy light where they stay on a few minutes after. Grammar and punctuation really do go a long ways when trying to convey a point or question though.
Old Jan 24, 2018 | 05:43 AM
hturner12's Avatar
hturner12
I try not to use the word fire around my truck
Old Jan 24, 2018 | 07:56 AM
Chevy_Eater's Avatar
Chevy_Eater
LOL, good point. Especially a Ford...
Old Jan 25, 2018 | 06:18 PM
eraser5's Avatar
eraser5
Ummm <cough cough>What ever do you mean? --says the guy who almost ran over his boss getting to a fire extinguisher.
Old Jan 26, 2018 | 12:29 AM
79ford351m's Avatar
79ford351m
Trailering
Crew cab 7.3 idi turbo won't start and all light stay on
When I go to turn my key nothing happens at all my dash lights up as it should and I can hear my glow plug relay clicking but there is no crank at all. but there is power to the starter solenoid because I can fire the truck up with a screw driver. My glow plug and starter solenoid are both new but I have my suspensions about the glow plug wireing harness being bad dose this harness send power directly from ignition to the starting solenoid? And my ignition switch is also new
Old Jan 26, 2018 | 12:35 AM
79ford351m's Avatar
79ford351m
Trailering
And when I pull my headlight switch out every light that is supposed to come on dose but when I push it back in they all stay on. I was told it could be a bad DRL but since they stay on after I let my truck run I disconnect the battery because my truck battery will die. Before this all happened the truck would start in half a crank and still dose when I jump it at the starter solinoid
Old Jan 26, 2018 | 12:37 AM
madpogue's Avatar
madpogue
Automatic or manual transmission?
Is this a Canada truck?
Remove and disconnect the headlight switch, and inspect the connector. Look for electrical/burn damage.
Old Jan 26, 2018 | 12:38 AM
79ford351m's Avatar
79ford351m
Trailering
Manual ZF5
Old Jan 26, 2018 | 12:39 AM
79ford351m's Avatar
79ford351m
Trailering
And it's from Canada
Old Jan 26, 2018 | 08:43 AM
madpogue's Avatar
madpogue
Doesn't matter where it's FROM. What country is it made FOR?
Check the clutch safety switch on the master pushrod.
Old Jan 26, 2018 | 02:32 PM
79ford351m's Avatar
79ford351m
Trailering
Old Jan 26, 2018 | 02:54 PM
madpogue's Avatar
madpogue
Without a build sheet, that says nothing about where it's built FOR.
Not sure how much easier to make this -- is the speedometer major scale in MPH or km/h?
Old Jan 26, 2018 | 05:37 PM
79ford351m's Avatar
79ford351m
Trailering
It's in mph it was made in Canada but sold in the us I'm in Pittsburgh PA
