Anyone install a sanden 805 AC compressor on a mid 70s 390.
I have a 1975 F250 w390 in C6 combo. It has the A/C compressor on the driver side but it is mounted upright rather than on the side like most other vehicles that we see of this era. Does anybody have a picture of a 390 of this era with a bracket that mounts the AC compressor on its side rather than standing up, the way it is on my truck. I appreciate a picture of the bracket to see if it's any different than the one that's on there so that I can change the mounting position if possible. I am thinking about using the double snorkel air cleaner on it, that is the reason why I was considering putting the compressor on its side again. Thanks..Mo
So it's the same bracket as the 460 which is on it's side then if my eyes are not deceiving me ND? I probably can do it if I get the other bracket #2888 but it shows the same # but the brackets look different? There a way to remove that duplicate post or not? I did it while at the coast on the stupid phone.
Factory A/C: 1976 360/390 and 1973/79 460 compressors mount the same, probably why Ford included both in the pic.
D6TZ-2882-A .. Compressor Mounting Bracket / Obsolete
1976 F100/350 360/390.
D0AZ-2882-A .. Compressor Mounting Bracket / Obsolete
1973/79 F100/350 460 / 1970/71 Thunderbird 429; 1970/72 Galaxie/LTD/Marquis/Torino/Montego 429; 1973/74 LTD/Marquis 429/460; 1973/76 Torino 429/460.
Ford basic numbers shown in pics are the same. The text section of the catalog is required to get the complete part number by adding the apropos prefix and suffix.
For example, every hood from 1928 thru today that is shown in pics is basic part number 16612, every piston is 6108, every carb is 9510 and etc etc etc.
I never cared much for the York, its heavy, noisy, inefficient and prone to vibration unless there are a lot of brackets and braces.
On my project I installed a Sanden compressor using a bracket that I got from Nostalgic Air. It bolts to the factory bracket set up. I also fabbed a second bracket to stabilize the factory bracket
I can't comment on the performance yet, my project is still a "work in progress".
lewistg
07-12-2016 08:40 PM
Mdc9966
13
09-22-2015 09:40 PM
73Custom
05-03-2006 01:10 PM
Charles-65F350
08-30-2001 03:47 PM
