upgrade NAV from 08 to 09+
I'm honestly looking to keep the Stock look and interfaces functional. the system has all that i want except for the bluetooth ability. i spend a ton of time in the car daily so being able to connect up is a must. and the aux input is not a clear signal, nor is it digital. so sounds are very off at different volume lvls. I am honestly interested in knowing if i can put the newer(nav with HD,BT and HDRadio) in my truck , are the wires the same, will all options work if programmed correctly or will i need a lot of additional modifications to make it work. ? thats what im really looking for.
Thanks
Thanks
UPDATE... I have viewed the images for a 2008(mine) and a 2009 + unit. there are an additional slot for harness connection that I do not have so I guess im stuck with aftermarket or Dealership package upgrade for sync module. 550$ from what i've seen. i dont know what the upgrade lincoln has for it but i hope it offers the additional functions i was looking for.
Thanks
Thanks
Thanks
Thanks
Gatortadpole
06-08-2008 09:14 AM
00Eddie
07-02-2006 08:13 PM
