upgrade NAV from 08 to 09+ - Ford Truck Enthusiasts Forums
2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Old 01-18-2018, 01:47 PM
04ExpeditionEB's Avatar
04ExpeditionEB
04ExpeditionEB is offline
04ExpeditionEB is starting off with a positive reputation.
Lightbulb upgrade NAV from 08 to 09+
Navigator has full nav system. but it lacks Bluetooth and other features that are available in the newer systems. curious if its plug and play with an 09 and newer or not, understand they contain internal hd too.
Options?
Thanks
Bill
Old 01-18-2018, 09:11 PM
alwaysfords41's Avatar
alwaysfords41
alwaysfords41 is offline
alwaysfords41 is gaining momentum as a positive member of FTE.alwaysfords41 is gaining momentum as a positive member of FTE.
I believe they have to be programmed to the VIN. If you look at resellers on sites like Ebay one of the things they offer is preprogramming the unit they are going to send you so it will act like plug and play.
Old 01-18-2018, 09:14 PM
neilster1
neilster1 is offline
neilster1 is starting off with a positive reputation.
You'll spend less money and get more features going with a current aftermarket unit and a maestro interface box..
Old 01-19-2018, 06:03 AM
04ExpeditionEB
I'm honestly looking to keep the Stock look and interfaces functional. the system has all that i want except for the bluetooth ability. i spend a ton of time in the car daily so being able to connect up is a must. and the aux input is not a clear signal, nor is it digital. so sounds are very off at different volume lvls. I am honestly interested in knowing if i can put the newer(nav with HD,BT and HDRadio) in my truck , are the wires the same, will all options work if programmed correctly or will i need a lot of additional modifications to make it work. ? thats what im really looking for.
Thanks
Old 01-19-2018, 06:17 AM
04ExpeditionEB
UPDATE... I have viewed the images for a 2008(mine) and a 2009 + unit. there are an additional slot for harness connection that I do not have so I guess im stuck with aftermarket or Dealership package upgrade for sync module. 550$ from what i've seen. i dont know what the upgrade lincoln has for it but i hope it offers the additional functions i was looking for.
Thanks
Old 01-19-2018, 10:32 AM
neilster1
Thanks
There's an interface module, the iDatalink Maestro that retains pretty much everything. Steering wheel interface, sync interfaces and sources if you have sync.. the whole ball of wax. in fact, the Maestro gave me more than I had before in the way of OBD code reading, per-wheel TPMS display, electronic gauge display. I'm using that module and a Pioneer AVH-4200NEX. Now I have android auto.. well worth it just for that.
jayhawk714
1999 to 2016 Super Duty
07-15-2017 11:16 AM
grampscamper
2017+ Super Duty
06-19-2017 08:47 AM
rvpuller
08-18-2016 07:37 PM
castone001
04-27-2016 02:08 PM
dlcorbett
02-16-2016 02:50 PM
Quick Reply: upgrade NAV from 08 to 09+
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
