Axle machining
Old 09-23-2017, 06:08 PM
CougarJohn's Avatar
CougarJohn
CougarJohn is offline
Axle machining
I got my '67 from the shop this week. I had the rear axle bearings replaced. The shop said they had to machine one axle because it was damaged.
What gives? What is there to machine on an axle? Sleeve over the grove where the seal rides?
Old 09-24-2017, 12:29 AM
351Cleveland C4's Avatar
351Cleveland C4
351Cleveland C4 is offline
Ask them? I can't think of anything other than what you said.
Old 09-26-2017, 01:15 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
B7TZ-4234-A (replaced B7C-4234-A) .. 9" Axle Shaft - Right/Left is the same / Obsolete
1957/67 F100.
Old 09-28-2017, 11:57 AM
JEFFFAFA's Avatar
JEFFFAFA
JEFFFAFA is offline
Prolly where the seal rides. If the lube level was low enough I suppose it possible the axle bearing was freezing up a tad and spinning on the shaft. The bearings are supposed to be at a friction fit. And then the retainer collar is supposed to be a press fit. Possible, but not probable. Come to think of it, maybe they screwed the pooch and messed up so the retainer collar was too loose. Had to fix that.
Fyrwlkr
06-18-2018 09:43 PM
ultraranger
18
02-22-2016 03:27 PM
Nightintruder
1999 to 2016 Super Duty
09-24-2012 12:18 AM
SirSparks
05-05-2012 12:08 PM
pitrow
03-15-2007 11:41 PM
Quick Reply: Axle machining
