Axle machining
Old Sep 23, 2017 | 06:08 PM
CougarJohn's Avatar
CougarJohn
Axle machining
I got my '67 from the shop this week. I had the rear axle bearings replaced. The shop said they had to machine one axle because it was damaged.
What gives? What is there to machine on an axle? Sleeve over the grove where the seal rides?
Old Sep 24, 2017 | 12:29 AM
351Cleveland C4's Avatar
351Cleveland C4
Ask them? I can't think of anything other than what you said.
Old Sep 26, 2017 | 01:15 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
B7TZ-4234-A (replaced B7C-4234-A) .. 9" Axle Shaft - Right/Left is the same / Obsolete
1957/67 F100.
Old Sep 28, 2017 | 11:57 AM
JEFFFAFA's Avatar
JEFFFAFA
Prolly where the seal rides. If the lube level was low enough I suppose it possible the axle bearing was freezing up a tad and spinning on the shaft. The bearings are supposed to be at a friction fit. And then the retainer collar is supposed to be a press fit. Possible, but not probable. Come to think of it, maybe they screwed the pooch and messed up so the retainer collar was too loose. Had to fix that.
Fyrwlkr
Jun 18, 2018 09:43 PM
ultraranger
18
Feb 22, 2016 03:27 PM
Nightintruder
Sep 24, 2012 12:18 AM
SirSparks
May 5, 2012 12:08 PM
pitrow
Mar 15, 2007 11:41 PM
