Axle shaft quandry?!
I have a '55 ford F-100 that has a donor 9" rear diff that didn't have an ID tag. I think I narrowed it down to a '77 Bronco but not sure. Replaced the ring/pinion. Had to do brakes so decided to do bearings and seals. When I did the bearings I noticed a small gouge in the drivers side axle at the seal race. I used emery paper to smooth it out but it didn't hold and the seal on that side is leaking. Tracking down a new axle shaft is crazy unless you get a "cut to fit". Here's what I know - The old shaft is a 28 spline, with 5.5 stud pattern, it had ball bearings so I think it's a "small bearing" set? and the shaft is 29 7/8" long from axle face to tip of splines. As long as I'm asking can a "big" and "small" bearing set be swapped out? Has anyone used the cut to fit and how did it work out?
enriched&beyound
24
06-12-2017 07:15 PM
ultraranger
18
02-22-2016 03:27 PM
