Is this a normal amount of metal on my transmission pan magnet?
So I just did the huge transmission pan upgrade and I also did the D solinoid upgrade along with the metal dummy plug and 6.4L filter. Amazingly it took 16 qts of Valvoline Max Life synthetic fluid. Highly recommend these upgrades, it's behaving like a new transmission. I barely notice the modded D solinoid shift bump if you want to call it that. Anyways I was having big problems when the the tranny was hot before I did these upgrades and the magnet had a good amount of metal on it. I had about 50k miles on the fluid and external filter.
Codes I got about a month ago.
50k miles on this fluid
I can't tell you if that's a lot, as I've only dealt with my own transmission. But I recently did the same 08 pan and filter on 45k mile fluid and I didn't have any of that metal on the magnet in the pan I replaced. I only had a thin film of darker stuff that wiped off with a rag. Not sure if that's good or bad.
There's no good database of quantity of metal on the magnet from an enthusiasts perspective, but someone who does a regular repair on the trans might have a good perspective.
From my trans pan video images with my truck, 200k miles without ever dropping the pan, lighter use of the truck then many. There is a good possibility that most of the wear debris is from the initial burnishing in of the friction and steels if a trans clutch pack performs in the same manner as vehicle brakes, polishing out any machining peaks to attain a smooth surface.
Thanks for sharing the pictures of your magnets, just to clarify I did not do the 6.4L pan. I got this:
Derale 14208: Transmission Pan Cooler Ford E40D/4R100/5R110/5R110W | JEGS
You just reminded my of one concern I have about the new Derale pan is that it has a magnetic drain plug only. I had thought of moving the original magnet into my new pan but got sidetracked and left it out. The drainplug magnet is super strong though. Probably over thinking it.
https://www.ford-trucks.com/forums/1...l#post13379514
Ruh Roh.... We've been down this rocky road before.... Based on what I have heard/read, it is unlikely. Here, start reading from about the post I permalinked:
