When setting is on ac low or max the fan blows out the vents for about 2 minutes then quits and blows thru the defrost vents for about the same and switches back
Check the white vacuum hose leading to the recirculation vacuum motor located on the passenger side of the engine bay. Very common problem. This time of year we see posts several times a week.
I first replaced as much of the brittle white vacuum line and that helped a little. Then I replace the vacuum motor and that helped a lot. Still a very slight problem but I can live with it.
So you checked this one mentioned and it was ok? The tubing could be cracked/ broken inside of the harness. Does the door actuator move when you change settings?
