Champion Radiator Question
Old 07-24-2017, 12:10 PM
Coastal68's Avatar
Coastal68
Coastal68 is offline
Anybody ever use one of these or any other Champion radiator? I need a replacement for my 68 250 with a 360 and a C6. I would like to use the stock fan and shroud. Also plan to add AC. This is a 3 row rad.
F-Series Truck Radiator (68-77) 24" tall core
Old 07-24-2017, 03:16 PM
Salty Dog's Avatar
Salty Dog
Salty Dog is offline
That's the one I'm using. Working fine. Stock fan and shroud.
Old 07-24-2017, 04:18 PM
Coastal68's Avatar
Coastal68
Thanks! Got it ordered.
Old 07-26-2017, 10:30 PM
Coastal68's Avatar
Coastal68
Got it installed this evening. The fit was perfect. The truck runs much cooler now.
Old 07-26-2017, 10:40 PM
Tedster9's Avatar
Tedster9
Tedster9 is offline
Is it OK to use reg'ler green antifreeze coolant 50/50 with the aluminum radiators? Or do they want the fancy schmancy organic free range gluten free stuff?
Old 07-27-2017, 06:50 AM
Coastal68's Avatar
Coastal68
This is from the Champion site FAQ page: "We recommend a 50/50 distilled water with antifreeze solution. If you're preparing your own solution it is imperative that distilled water is used as regular tap water will damage the radiator and void the Lifetime Warranty."
Old 07-27-2017, 09:02 AM
Tedster9's Avatar
Tedster9
Tedster9 is offline
That sounds right. I remember they had some kind of warning right on the box.
Old 07-27-2017, 12:14 PM
CrossPlainCrazy's Avatar
CrossPlainCrazy
CrossPlainCrazy is offline
I personally have been looking at this radiator because I like that it has the same looking form as the stock tank and not just aluminum sheets welded together. Has anyone used an KKS radiator?
KKS 3 Row Aluminum Radiator For 1978-79 Ford Bronco 1968-79 F-Series Trucks | eBay
Old 07-27-2017, 04:23 PM
JEFFFAFA's Avatar
JEFFFAFA
JEFFFAFA is offline
Bwa ha ha ha!
i-w
06-15-2019 08:47 AM
rquinlans
07-16-2011 10:49 AM
Jupes
04-30-2011 09:03 PM
bicyclemonkey
16
09-15-2009 09:58 PM
Jfrost
09-07-2006 12:47 PM
Quick Reply: Champion Radiator Question
