06 F-250 6.0 Transmisson issues please advise.
Hello everything,
I currently have a 2006 F-250 6.0 with 187,XXX.
My problem that i am having is that the transmission recently within a couple weeks started acting weird about the same time 3 of my fuel injectors started failing. When i start up the truck and put it into drive it takes about 3-5 seconds to shift. Once it's in drive it runs pretty well but it will start shifting out of normal when i go to accelerate. Also when i go to slow down sometime the transmission shifts hard to a lower gear. I also have a video of the sound that it had started to make since its hard to describe.
Here are attached videos and photos. I want to hopfully fix the problems myself so i can learn more about my truck. I am going to handle the fuel injectors here soon since 2 are failing and ones about to these have been causing the truck to shudder at around 47-53 mph but after that its fine. I really want to find someone here that has experience or knows what could possibly be wrong.
The transmission is stocked and never been altered, i do admit for 3-4 years i have changed the fluids or filters.
The truck is bullet proofed, sct tuner, upgraded turbo from stock, 4" exhaust, head studs and new everything when the engine was rebuilt and bulletproofed.
Hope someone can help me i plan on going to ford tmw to have them figure out the problem and hopefully its just solenoids so i can fix it myself.
I have a link posted also where you can hear the noise it has been making when in R P and when shifting going down the road and it is a automatic.
Thank you all in advance for all your help and goodness.
Transmisson
Transmission
Codes
Transmisson
Transmission
Codes
Last time i checked my batteries where doing fine and they were the correct voltage which about a month ago. I will check again today.
Truck ran great this morning on the way to work just that weird sound is happening when the truck shifts. I was cruising at 80mph today with no issues shifting to that speed.
Replace 3 injectors
$1600
Replace 8 injectors
$2500
Do you by chance know what that sound is and where it's coming from and why?
This is the first time messing with the injectors would it better to have a shop replace all the injectors for $2500 since he can get the Warn injectors for $225 a pop. Or with all the right tools i need to buy should i just replace 3 bad ones myself and save some cash or replace all 8?
Gotcha, I had a computer hooked up and it shows 2 failing and 1 about to start failing so fuel injectors for sure need to be replaced sadly. I am debating on having someone do the 3 for $1,600 or do all 8 for $2500 or i do 3 for around $1,000
