2001 f250 interior swap
Yes. There's a ton of information on here regarding dash swaps, door panel swaps, etc. seats should bolt right in.
This is a good place to start: https://www.ford-trucks.com/forums/1...dash-swap.html
Everything can be swapped. I just completed mine and have a FULL 2012 Lariat interior installed in my 07. I did everything from the carpet to the headliner. All trim pieces fit with minor modifications including the new seatbelts. I went the extra step and installed the rear middle shoulder belt. I got the brackets from a junk yard and welded them in. If you sit in my truck now you would never know it was an 07
I found 08+ mirrors on ebay for $115 to replace my tired factory mirrors on my 04.
The mounting bolts are good but not perfect. The plastic cowl piece does not lay perfectly flat no matter what even after trying to re adjust the mounts.
Every thing else is good but if you want a perfect fit spend more money.
Hillbilly_Deluxe
13
12-11-2009 06:00 AM
