I just picked up a 1948 F2, I like the truck, but hate the transmission (4 Speed).
What are my options for either a synchronized manual, or auto transmission.
I plan to do the explorer rear end swap, as well.
Likely the 239 flathead - we just did a manual transmission swap on a 49 Mercury M68 (equivalent of the F3 so much of the drivetrain is the same I believe). Same engine block. The options that easily bolt up seem to be a Mustang Worldclass T5, or a S10 - we went with a 5-speed S10 which is not quite as robust but will be fine for what we plan to do with the truck. Anything else doesn't bolt up as easily and will require more adaptation. Never considered an automatic, so can't help you there.
Rear end on ours is now out of a Bronco - width works out well.
Others here helped us to narrow down that choice - I'm sure they will weigh in.
I bought mine complete with the e-brake. My T9 brake would have bolted on if I didn't get it. The only mod you would have to do is cut the hole in the trans cover.
If you have a working e-brake and don't want to use the trans mounted one just take the trans mounted parts off. The drive shaft will still bolt up without the drum in place. The drum is mounted behind the flange. You might need shorter mounting bolts?
