Sponsored by: Auxito
99 ford 7.3 turbo diesal added 2 much oil
Old Oct 10, 2010 | 10:21 AM
Zephyrhills Ford's Avatar
Zephyrhills Ford
What is going to be the outcome if I overfilled my engine by 3 quarts and tryed to start it. It would barely turn over then i realized what i did so i drained some out but it still wont crank. did i ruin my engine what are my options?
Old Oct 10, 2010 | 04:41 PM
jgeese's Avatar
jgeese
You would be better served by posting this question in the "diesel" section...
Old Oct 10, 2010 | 05:09 PM
steve(ill)'s Avatar
steve(ill)
i cant see that 3 quarts oil oi lwould do much damage. maybe the motor has a crank case breather / PCV type valve and the higher oil level got pushed backward into the intake and filled on cylinder causing hydraulic lock ? If it wont turn over, i would thing some type hydrualic lock occured. YOu might have to remove the injetctors and rotate the motor a few revolutions... can you rotate the crank backward by hand with a wrench ont the flywheel ?
79FORD-DENT
Jan 26, 2011 01:18 AM
rvbuilder2002
Nov 13, 2010 05:46 PM
68murc
Apr 27, 2007 04:43 PM
edward327
4 Cylinder Engines
Dec 1, 2005 11:20 AM
jadel
22
Feb 19, 2005 04:15 PM
