ive got a ford 360 with a automatic trans and elec ing. , it was running fine all the sudden it started missing just a little a little bit later it back fired and started runnin really bad did not feel like it was running on all cylenders , i pulled the cap and rotor and there was some oil all over under the cap so i replaced the cap and rotor and it stilll isnt runng very well any ideas please help if you can its all i have to drive
Check the plug wires, make sure the distributor hold-down is tight, check for a vacuum leak, and as a sanity check make sure the timing is set correctly.
no oil under cap as of yet plugs look ok and timming is good could the electrics in the disturburter be gummed in side i was thinking spraying he hell out of it with break kleen good idea or bad
Did you actually check any of the stuff I told you to check?
FMC400 i did check what you told me to and same issue ,then i got a can of arosol elextrode cleaner was alot better and just a bit ago when its gettin derk i fired it up and found a pin whole in the number 1 wire it was sparking changed with old wire and bang runnin like a chanp so you were right for the most part little cleanning and a wire and itss good to go
