please help 74 360
Old Oct 5, 2010 | 12:55 AM
juchertf100's Avatar
juchertf100
please help 74 360
ive got a ford 360 with a automatic trans and elec ing. , it was running fine all the sudden it started missing just a little a little bit later it back fired and started runnin really bad did not feel like it was running on all cylenders , i pulled the cap and rotor and there was some oil all over under the cap so i replaced the cap and rotor and it stilll isnt runng very well any ideas please help if you can its all i have to drive
Old Oct 5, 2010 | 09:14 AM
fmc400's Avatar
fmc400
MSEE
Check the plug wires, make sure the distributor hold-down is tight, check for a vacuum leak, and as a sanity check make sure the timing is set correctly.
Old Oct 5, 2010 | 10:05 AM
John in AZ's Avatar
John in AZ
Did the new cap get oil all over it also? if so might be a distributor problem.
Old Oct 5, 2010 | 11:55 AM
juchertf100
no oil under cap as of yet plugs look ok and timming is good could the electrics in the disturburter be gummed in side i was thinking spraying he hell out of it with break kleen good idea or bad
Old Oct 5, 2010 | 08:04 PM
fmc400's Avatar
fmc400
MSEE
Did you actually check any of the stuff I told you to check?
Old Oct 5, 2010 | 08:56 PM
juchertf100
FMC400 i did check what you told me to and same issue ,then i got a can of arosol elextrode cleaner was alot better and just a bit ago when its gettin derk i fired it up and found a pin whole in the number 1 wire it was sparking changed with old wire and bang runnin like a chanp so you were right for the most part little cleanning and a wire and itss good to go
thanx guys.......
Old Oct 6, 2010 | 07:14 AM
fmc400's Avatar
fmc400
MSEE
Glad to hear you got it worked out.
Old Oct 6, 2010 | 10:23 AM
juchertf100
thxnx ,its running a little rich now and not sure why
rtcabal
Dec 25, 2014 12:45 AM
JRS75f100
Jun 29, 2012 08:49 AM
xevious
Mar 31, 2011 11:13 PM
lowcountry
Electrical Systems/Wiring
Jul 11, 2004 05:55 AM
drjackpaul
May 1, 2004 10:00 PM
