Help! '69 360 ignition issue
Old Dec 20, 2014 | 09:52 AM
rtcabal's Avatar
rtcabal
hi gang;
the truck was running when parked. i did some work that required me to remove the distributor cap, now it won't start...
-new coil, getting votage (about 5-6 volts? going off memory); resistance checks out on the coil
-new condensor
-rotor, cap, plugs and wires are new
-with the cap off, rotating the engine by hand i can see the points open and close appropriately (with the key on there's a little spark when they open)
-i put cylinder 1 at TDC by hand, then repositioned the plug wires accordingly (1-5-4-2-6-3-7-8). there is no timing mark on my pulley, so i pulled the spark plug and used a feeler to get it to TDC
its got a new edelbrock carb that is getting gas...
its turning without firing at all. it did this once before and i replaced the wiring going to the coil, and it fired right up.
any help, suggestions, ideas are appreciated.
THANKS
Old Dec 20, 2014 | 10:18 AM
orich's Avatar
orich
Best to find TDC with placing your thumb over the plug hole while cranking or bumping the engine. use a remote push button switch on the solenoid. Or a screw driver can be used jumping the large Batt. wire and the (S) wire on the solenoid. Its the wire next to the large Battery cable. Or have a helper use the ign switch you may need to put a wrench on the crank bolt for alignment on the crank pulley. You may need cleaning to find the markings or it's just a bump tit on it..
A new common problem is bad condensor from china, so may be replace it with the old one..
Orich
Old Dec 20, 2014 | 10:31 AM
rtcabal's Avatar
rtcabal
anyway to test the condensor? the old one's wire broke off right at the terminal; hard to even solder it back effectively.
it wont fire at all without a properly functioning condensor, correct?
i found a 'tc' mark on the pulley, lined it up and the rotor was pointing at #1 plug wire.
the rotor rotates counter clockwise, right??
i'm soooooo confused.
Old Dec 20, 2014 | 03:04 PM
CougarJohn's Avatar
CougarJohn
Replace the condenser. A few bucks.
Pretend that you are shooting a b-b into the vacuum advance port. The engine turns in that direction.
Old Dec 20, 2014 | 04:16 PM
kenny nunez's Avatar
kenny nunez
no spark
x2 on the condenser, do your self a favor and only get your ignition parts from NAPA until you convert to a Petronics system. Also you should have 12 volts on the Bat side of the coil when the starter is turning the engine.
Good Luck
Old Dec 20, 2014 | 04:33 PM
Bullseye72's Avatar
Bullseye72
I replaced the condensor on mine with a BW_SOMETHING from O'REILLY. $7. Fixed alot of headaches for me.
Old Dec 20, 2014 | 07:38 PM
rtcabal's Avatar
rtcabal
thanks for the help!
here's what i did today:
-new condensor
-i pulled the plugs (actually went ahead and changed the plugs and wires)
-i used a feeler in the spark plug ports to determine TDC. I went in firing order, watched the rotor, etc... i thought i had the timing NAILED.
still not even trying to fire. the only thing i havent replaced are the points.
the advance auto has a petronix unit on the shelf...
i have not checked cranking volts, but thats on my list now. (though the coil gets good spark with the engine block test).
i also used a timing light to to test my markings, and it seemed close. maybe not great, though.
again, all input is greatly appreciated!!!!
Old Dec 20, 2014 | 09:31 PM
kenny nunez
ignition
If you end up installing the Petronics you will have a smoother running engine and the timing will stay more steady.
Old Dec 20, 2014 | 09:47 PM
orich's Avatar
orich
check points gap .017 & 0.34 on plugs. Check the ground wire in dizzy that not broken.
Check for dizzy shaft for to much back & fourth side to side play & points are opening when you crank the motor or over. If ok then try doing my Hot wiring idea.
Check point wire for been, I've seen some where they shorting to the block.
orich
Old Dec 22, 2014 | 02:13 PM
FECruzer69's Avatar
FECruzer69
Is it possible that there may be a speck of dirt or a bit of grease in the point gap? I've had it happen to me.
Are you still getting a spark at the points with the cap off?
FYI; Just in case it's after hours or a holiday, or you don't want to make a run to the parts store, it is possible to test a condenser. If you have a "Multi-meter" or VOM, just set it to the highest OHMS function.
- Disconnect the Condenser lead from the points and momentarily ground the lead. Don't leave it grounded.
- Connect the Positive (+) test lead to the Condenser lead.
- Touch the Negative (-) test lead to the metal body of the Condenser.
You should get an Infinite reading (no reading at all). It should not read zero Ohms. If you get a reading of zero Ohms or any reading other than infinite, then the condenser is defective.
Old Dec 22, 2014 | 02:44 PM
JEFFFAFA's Avatar
JEFFFAFA
Well,1st,while you're still points ignition get a real condensor from your local Ford Dealer. Ford V8 single points Dizzys take condensor number C9AZ12300A and points part number B8Q12171A.
2ND,what happened in the beginning which made you work on it? Just a tune-up or something else?
3rd,with everything hooked up and cranking over,is it hitting every once in a while? Or just spinning like a top not trying to start at all?
Old Dec 22, 2014 | 08:01 PM
jfmaz's Avatar
jfmaz
Any chance you are finding BDC for #1 cyl instead of TDC?
180* off?
Old Dec 25, 2014 | 12:45 AM
slpcth's Avatar
slpcth
[QUOTE=rtcabal;14921910]hi gang;
Just what work did you do? It is hard to advise you not knowing what was done. Since it was running when parked and stopped running after it was worked on I would retrace my steps and make sure I did not make a mistake or install a faulty part.
HIO Silver
55
Apr 21, 2016 11:36 PM
55fordv8
May 27, 2012 01:24 PM
Links_vette
Nebraska Chapter
26
Feb 25, 2009 10:00 PM
harleyclassic
Mar 14, 2004 04:39 PM
pancake
1983 - 2012 Ranger & B-Series
Aug 25, 2003 09:26 AM
