Big Truck ID
Old Sep 16, 2010 | 09:36 AM
Idaholar's Avatar
Idaholar
Big Truck ID
I need some help identifying my 47 flatbed turned small dump. I've searched the forums but haven't been able to turn up the specific info that I'm after so any help would be greatly appreciated.
ID plaque reads 12500 GVW, Engine 799 T 1549100-unclear, Model 798T, H P 87. Wheel base is 158 inch.
For parts ordering purposes I'd like to know if it's a 2 ton or what.
Thanks for any help.
Larry Dehart.
Old Sep 25, 2010 | 03:56 AM
Steve Christensen's Avatar
Steve Christensen
Hi, from what I see in my '39-'48 Ford / Mercury shop manual, in regular trucks 1 1/2 ton and bigger the brakes & suspension specs seem to be the same, wheel bases / chassis lengths and diff ratios vary. Mine is a 1 1/2 ton, 134'' wheel base duels on rear axle and it had 1 1/2 ton painted on the door when I got it .
Old Sep 27, 2010 | 08:40 AM
Idaholar's Avatar
Idaholar
Interesting. Mine also has duels with a wheel base of 158". I'd read in a post from about 2004 that tire size could help determine tonnage. Mine are 7.50 x 20 front and 8.25 x 20 rear.
So 1 1/2 ton was painted on the door, not 12500 gvw or something like that?
Old Sep 27, 2010 | 10:19 PM
1952's Avatar
1952
I believe the two tons had a two speed rearend. One of the reasons Ford went to a "two ton" was customers were sourcing two speeds from the aftermarket. Ford figured they were missing out, and the rest is history.
Old Sep 28, 2010 | 08:49 AM
Idaholar's Avatar
Idaholar
I see. Mine does have a two speed rear end. Top speed is around 45 mph in the high range, 20 or 25 in the low range. It pulls good with a load though.
Old Sep 29, 2010 | 09:54 AM
F6Guy's Avatar
F6Guy
just a little something to think about I have seen a few pictures of what is refered to as a three ton. there are a couple pictures on hanks truck pictures website, it looks like a 1.5 ton but has a two speed rear and six lug wheels. I think it was a 1939 model.
Old Sep 30, 2010 | 10:59 AM
Idaholar's Avatar
Idaholar
Wow! Thanks for the steer to that web site. Trucks to spare. A little bewildering at first but something in there for everybody. Hank's Truck Pictures
Old Oct 12, 2010 | 08:35 AM
Idaholar's Avatar
Idaholar
Still looking for help.
Old Oct 14, 2010 | 12:31 AM
mtflat's Avatar
mtflat
Larry Dehart.
Larry, I can only give you some basic info. I have 48 two ton, a 50 1 ton and a 52 two ton. The 48's tended to be very similar to the 47's as far as chassis went.
The serial number means:
7 - 1947
9 - V8
9T - model (truck larger than 1 ton)
1549100 - serial string
87 might be body code
12,500 gvwr in 1948 would have fallen in the range for 1.5 ton trucks. 1.5 ton trucks with 158" wb were rated between 11,500 and 14,000. Tires ranged from 7.00x20 to 7.50x20
Two ton trucks with 158" wb were rated at 15,000 and tires were 8.25x20
Both 1.5 and 2 ton trucks could have the two speed rear end, and the same spring packs could be ordered on both.
Hope it helps. For what its worth, most of the parts swap and were exchanged between 1 ton, 1.5 ton and 2 ton trucks. There doesn't seem to be much difference except for frame dimensions and tire size.
Nice truck!!
Tim
Old Oct 14, 2010 | 07:18 AM
Idaholar's Avatar
Idaholar
Tim, thanks very much. Kalispell is just over a couple of mountains from Sandpoint. Great info and as I suspected there isn't any way to tell exactly what the truck started life as. As you pointed out, as far as parts go, there isn't any real need to pin it down any closer.
Thanks again.
Larry
Nice truck!!
Tim
bbender85
Nov 20, 2015 04:34 PM
cowboybootlegger
18
Sep 3, 2015 08:39 PM
bbender85
May 29, 2013 06:52 AM
drbalazo
1978 - 1996 Big Bronco
Dec 15, 2011 09:45 PM
cowboybootlegger
Dec 6, 2010 02:22 PM
