Big Truck ID
Big Truck ID
I need some help identifying my 47 flatbed turned small dump. I've searched the forums but haven't been able to turn up the specific info that I'm after so any help would be greatly appreciated.
ID plaque reads 12500 GVW, Engine 799 T 1549100-unclear, Model 798T, H P 87. Wheel base is 158 inch.
For parts ordering purposes I'd like to know if it's a 2 ton or what.
Thanks for any help.
Larry Dehart.
Larry Dehart.
Hi, from what I see in my '39-'48 Ford / Mercury shop manual, in regular trucks 1 1/2 ton and bigger the brakes & suspension specs seem to be the same, wheel bases / chassis lengths and diff ratios vary. Mine is a 1 1/2 ton, 134'' wheel base duels on rear axle and it had 1 1/2 ton painted on the door when I got it .
Interesting. Mine also has duels with a wheel base of 158". I'd read in a post from about 2004 that tire size could help determine tonnage. Mine are 7.50 x 20 front and 8.25 x 20 rear.
So 1 1/2 ton was painted on the door, not 12500 gvw or something like that?
I see. Mine does have a two speed rear end. Top speed is around 45 mph in the high range, 20 or 25 in the low range. It pulls good with a load though.
Wow! Thanks for the steer to that web site. Trucks to spare. A little bewildering at first but something in there for everybody. Hank's Truck Pictures
Larry Dehart.
Larry Dehart.
Larry, I can only give you some basic info. I have 48 two ton, a 50 1 ton and a 52 two ton. The 48's tended to be very similar to the 47's as far as chassis went.
The serial number means:
7 - 1947
9 - V8
9T - model (truck larger than 1 ton)
1549100 - serial string
87 might be body code
12,500 gvwr in 1948 would have fallen in the range for 1.5 ton trucks. 1.5 ton trucks with 158" wb were rated between 11,500 and 14,000. Tires ranged from 7.00x20 to 7.50x20
Two ton trucks with 158" wb were rated at 15,000 and tires were 8.25x20
Both 1.5 and 2 ton trucks could have the two speed rear end, and the same spring packs could be ordered on both.
Hope it helps. For what its worth, most of the parts swap and were exchanged between 1 ton, 1.5 ton and 2 ton trucks. There doesn't seem to be much difference except for frame dimensions and tire size.
Nice truck!!
Tim
Tim, thanks very much. Kalispell is just over a couple of mountains from Sandpoint. Great info and as I suspected there isn't any way to tell exactly what the truck started life as. As you pointed out, as far as parts go, there isn't any real need to pin it down any closer.
Thanks again.
Larry
Thanks again.
Larry
cowboybootlegger
18
09-03-2015 08:39 PM
bbender85
1997-2006 Expedition & Navigator
05-29-2013 06:52 AM
cowboybootlegger
12-06-2010 02:22 PM
