Can I drop my trans
Old Jul 19, 2010 | 06:51 AM
first_stater's Avatar
first_stater
Can I drop my trans
in the driveway using drive on ramps so I can replace my TC.
I need to buy a trans jack and either some ramps or up grade my jack stands.
I do have some old cinderblocks laying around
1994 E150 5.8 E4OD
Old Jul 19, 2010 | 12:44 PM
Lazy K's Avatar
Lazy K
It would be possible. Many years ago I pulled and refitted a C6 like that, but with a helper. And the E4OD is a huge trans. with around 17qts of fluid in it. Also I wouldn`t be happy with cinder blocks but maybe i`m over cautious. I also had a second jack to go under the engine.
If you do go for it make sure the new torque converter is fully seated in the trans before you bolt everything up.
Old Jul 19, 2010 | 12:50 PM
andym's Avatar
andym
DO NOT USE CINDER BLOCKS for anything automotive related. It's an excellent way to get killed, maimed, or disfigured for life.
Old Jul 19, 2010 | 02:05 PM
85e150's Avatar
85e150
You might get it out, but getting it back in....
X3 on cinder blocks. No no no.
Call me chickenfeathers about stuff like this, but I would have a shop do it.
Plus, you need to replace your TC because.....?
Old Jul 19, 2010 | 03:31 PM
jim henderson's Avatar
jim henderson
Don't the rental shop still rent good trans jacks?
I did a tranny drop way back using a rental jack and it was slick. Way safer than blocks.
The tranny is heavy, you don't want it to slip.
Good Luck,
Jim Henderson
Old Jul 19, 2010 | 04:46 PM
first_stater
Thanks guys,
Was kidding about the cinder blocks.
The truck is throwing code 728. Torque converter clutch slippage. I've got all four gears but no lock up. It shifts real nice until it codes and boosts line pressure and I have to keep resetting it.
I'm gonna try just a TC first. I'll have to buy one anyway if it needs to be rebuilt. Maybe I'll get lucky.
Old Jul 19, 2010 | 05:13 PM
andym's Avatar
andym
I sure hope it's not the solenoid pack connector or the solenoid pack itself.
Old Jul 19, 2010 | 06:12 PM
first_stater
If a new TC doesn't fix it at least the solenoid pack can be done with the trans in place.
I hope.........
Old Jul 19, 2010 | 07:54 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The hard part is that the E4OD weighs 270 pounds.
