It would be possible. Many years ago I pulled and refitted a C6 like that, but with a helper. And the E4OD is a huge trans. with around 17qts of fluid in it. Also I wouldn`t be happy with cinder blocks but maybe i`m over cautious. I also had a second jack to go under the engine.
If you do go for it make sure the new torque converter is fully seated in the trans before you bolt everything up.
The truck is throwing code 728. Torque converter clutch slippage. I've got all four gears but no lock up. It shifts real nice until it codes and boosts line pressure and I have to keep resetting it.
I'm gonna try just a TC first. I'll have to buy one anyway if it needs to be rebuilt. Maybe I'll get lucky.
