HELP!! 97 f150 trans problems
Old Jul 16, 2010 | 11:48 PM
frgtflrcn's Avatar
frgtflrcn
I have a 1997 f150 2wd super cab. 4.6 v8 with the 4r70w. driving up the road tonight i stepped on it to go up a hill and when it went to shift into 3rd gear there was nothing there. i dropped it into manual 2 and got where i needed to.
it will not shift into 3rd gear at all now. never had an issue before tonight...
the other problem is now it is making a horrible whining noise, almost like a dry PS pump, when it is in P N or OD. the sounds goes away in M1 M2 and R... fluid level is good...
any ideas, i really dont want to replace the trans....
Old Jul 16, 2010 | 11:57 PM
frgtflrcn's Avatar
frgtflrcn
oh and i put my diagnostic scanner on it tongiht and there are no codes... datastream looked ok
Old Jul 17, 2010 | 04:18 PM
dustybumpers's Avatar
dustybumpers
haveing gone through this, I want to save you some time and money. I changed mlps, all wiring haresses, cleaned valve body, changed oil and filter, changed servos, and acumulaters, all through the bottom . now the truck is at a trans shop, never did get it right. found that the problem, is that the torque converter goes bad, then wacks out o/d band, and clutches. you can still drive [I did anyway] with o/d canceled on the gearshift. that will go for a while, then 3rd quits, makeing you repair it. tough doing 65 with the tach at 4 grand. every trans shop is different, price ranges from $1400 to $3000, the last one po'd me, I told him I could buy a new truck for that amount. from what I'm told, this is a very good trans, so it is worth fixing.
Old Jul 17, 2010 | 05:57 PM
frgtflrcn's Avatar
frgtflrcn
well looks like ill be going to the junkyard... they got one for $475 and thats all i got for now.... thanks for the info, this saved me a ton of time
Old Jul 17, 2010 | 08:35 PM
dustybumpers
that's cool though, put in the jy one, and practice on the other one, rebuilding it, it's already broke, so you can't hurt it, who knows you may be succesful, and have a new tranny ready when the jy one goes up
Old Jul 17, 2010 | 09:46 PM
frgtflrcn's Avatar
frgtflrcn
actually there is a guy around here buying cores... ill put int he JY one and he offered me $150 for my core
HDWMAN
Modular V8 (4.6L, 5.4L)
Aug 12, 2016 04:37 PM
joegeds
16
Jan 18, 2015 07:29 AM
4BT-F150
Oct 29, 2009 08:40 PM
natewoz
Oct 25, 2007 01:36 PM
mlohaus
Nov 4, 2005 05:30 PM
