I need help diagnosing c-6 whine.
Old Jul 13, 2010 | 11:00 AM
meck1's Avatar
meck1
I need help diagnosing the source of a noise in my c-6 automatic tranny in an '87 f250. I've got a whining sound coming from the front of the transmission. It sounds like it is in the general area of the torque converter. What is different to me from most noises is that it is constant. It doesn't vary with engine speed or road speed. The only change in its sound is when I go from neutral (or park) into a gear. When the engine drops at going into gear, there is a second or two in which the whine drops in its frequency. Then it immediately returns to the constant whine of before.
Can anyone give me a clue as to what this might be? Any help will be appreciated. The transmission works perfectly, and if the whine is a sound of trouble coming, I would like to repair it before any damage is done.
Old Jul 13, 2010 | 12:34 PM
Lazy K's Avatar
Lazy K
Is the fluid level good? Does the fluid look clean with no burnt smell?
Old Jul 13, 2010 | 03:35 PM
meck1's Avatar
meck1
The fluid looks and smells good and is right up to where it ought to be. It (the tranny fluid) has about 10-12000 miles on it and a new filter. Got any ideas what's going on?
Old Jul 14, 2010 | 07:02 AM
Lazy K's Avatar
Lazy K
My thoughts were that, as the noise is constant and does not change with engine speed, it is unlikely to be a rotating part. So I thought maybe air in the pump due to low fluid level or maybe frothing of the fluid due to too much fluid.
However as the fluid and fluid level are good that is ruled out.
Can`t think of anything else, other than the fluid, that would make a noise that wouldn`t change with engine speed.
Old Jul 16, 2010 | 04:34 AM
meck1's Avatar
meck1
Thanks for your help. I appreciate it.
Old Jul 16, 2010 | 10:09 AM
mark a.'s Avatar
mark a.
A bad converter can sound just like you are saying & still seem to work ok.
Old Jul 16, 2010 | 10:12 AM
MonaVie1's Avatar
MonaVie1
Check your converter bolts, make sure tight and none missing.
Old Jul 19, 2010 | 09:34 AM
mikeo0o0o0's Avatar
mikeo0o0o0
An off-the-wall possibility, check the vacuum line from the transmission where it connects to the intake manifold. Sometimes a vacuum leak can sound like a whine.
ScaldedDog
22
Nov 2, 2020 08:18 PM
tookey71
Aug 10, 2011 08:52 AM
5.4L to Freedom
Dec 16, 2010 05:51 PM
blackjack28
15
Jul 10, 2007 09:45 AM
BigRed FX4
Jan 30, 2005 05:50 PM
