shifters for dents
Old Jun 3, 2010 | 08:25 AM
Kalve's Avatar
Kalve
shifters for dents
I was wanting to know if anybody knows what shifters would fit a 73-79 ford truck with a 4 speed manual trans on the floor? I am getting ready to put the trans an clutch an everything back in it an I am wanting to replace the shifter I would like to find a short shift for it if I can. Can anybody help me?
Old Jun 3, 2010 | 04:32 PM
dynamic's Avatar
dynamic
sawsall and a set of taps!
Old Jun 5, 2010 | 09:20 AM
Kalve's Avatar
Kalve
Is there any place that might carry a universal short shift for a 4 speed manual trans? An sawsall an a set of taps? the shifter has a lot of play in it that is why I am looking to replace it an was wanting to go with a short shift if I can.
Old Jun 5, 2010 | 11:39 AM
4x4 Bart's Avatar
4x4 Bart
I have never seen any short shifters except homemade. They were cut off and then rethreaded on the end for a shift ****. To fix the slop in the shifter it needs to be rebuilt to original specs. These transmissions were not designed for speed shifting as the gears have too much weight for a car type synchronizer. They have heavy duty truck style synchronizers. There are no aftermarket shifters.
Old Jun 5, 2010 | 11:44 AM
Kalve's Avatar
Kalve
so what do I need to do to get it rebuilt?
Old Jun 5, 2010 | 10:28 PM
dadsold76's Avatar
dadsold76
It may not be a short shifter, but i have a hurst shifter on the floor and i love it . its the best thing i ever did, the make them in 3 and 4 speed applications, and even though its not a short throw, i can still slam it into gear pretty quickly, you can find them all day long at summit racing
Old Jun 5, 2010 | 10:50 PM
joerickson's Avatar
joerickson
i think the only other kind of shifter ever offered for these vehicles was a gear bender or gear banger (if I remember correctly)
Old Jun 6, 2010 | 08:37 PM
4x4 Bart's Avatar
4x4 Bart
New, they had about 1/2" to 3/4" slop in both directions. To rebuild them, they have a ball on the end that wears flat on the sides. You have to weld the ball and file it, to make it round again and back in spec.
These are heavy duty truck transmission and are not designed to be precision shifters. Its just a different animal from a car trans. If it doesn't have more that an inch slop in it, there is not much to be gained by rebuilding the shifter.
Maybe you should look into swapping in a ford four speed top loader or T-5, etc., for blasting around the streets.
Deluxe06
26
Mar 2, 2011 04:38 PM
UncSam
Aug 26, 2010 01:59 AM
Pappys53
Jan 21, 2009 02:49 PM
chicaembragada
Aug 5, 2005 11:00 PM
